Anyone with big, high current amplifier(s) find a power conditioner that doesn't destroy the amplifier's virtues? Is it even possible? Which Ones?
caesar
3,439
213
498
#1
Most power conditioners suck the dynamic life out of amplifiers. Anyone find a power distributor that works great with high-current amplifiers?
Likes: Alrainbow
spiritofmusic
11,459
2,328
603
E. England
#2
Caesar, go balanced power. All ups, no downs. My £300 Airlink 3kVA BPT stomped all over my old £4.5k Burmester 948 conditioner.
BlueFox
1,435
151
285
#3
Shunyata. No issues at all. Well, there is improved sound, dynamics, etc., but that isn't an issue.
Likes: Alrainbow
Vienna
406
289
145
44
#4
My Torus AVR is a perfect match with the Mephisto
Likes: sujay
Mike Lavigne
Apr 25, 2010
8,870
2,658
770
#5
my Equi=tech 10WQ 10kva balanced wall panel system seems to do full justice to my 550 watt into 8 ohm darTZeel 458's just fine.
i've tried the standard outlets sitting right next to my balanced outlets (easy to A/B) and it's no contest as far as dynamics and refinement. not even very close.
Bodhi
1,052
341
155
#6
I use a Gigawatt PC-3 SE Evo conditioner which i've found is one of the few non-current limiting conditioners. There are many reasons for that, but having a-b compared running my Vitus amp direct to wall vs plugged into the Gigawatt, I clearly preferred the latter.
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,604
573
485
San Diego, CA
almaaudio.com
#7
I've had other conditioners that were non-limiting, so I think we're past that. The Niagara is a good example.
But the first one to actually *boost* dynamics, and make the amp sound freer, more open and relaxed, was the Gigawatt PC-4 Evo+.
With the two D'Agostino Momentum plugged, plus ARC preamp (+ sources), it's crazy dynamic. The DAC loves it too.
It's now a permanent fixture in our reference room.
Likes: Jazzhead
Folsom
4,992
833
270
Eastern WA
#8
Yes, been building them for years.
The problem is if your gear has a bad filter on it that's incompatible, or if getting rid of harshness sounds like less dynamics to you. A lot of people expect music to be dynamic that seemed like it was previously, but it was mostly problems making it sound that way. If you're older and hearing is declining you may not hear the harsh side at all, it might be a benefit.
Basically I'm saying it can be very hard for someone to judge dynamics. Sometimes you learn your stereo needs improvements when you have clean power (at least to get *back* to where you were in some characteristic).
Bodhi
1,052
341
155
#9
Your above response implies the Gigawatt PC-3 SE Evo model I referred to is only non-current limiting. In fact, like the PC-4 Evo+ it delivers equal and stable power distribution regardless of the load on any of the conditioner’s outputs & has a double buffering circuit with compensation cells with enhanced capacity which improves the impulse response with non-linear loads like power amplifiers, and levels the difference between input and output power of the conditioner, thereby improving dynamics. You should get your facts straight.
Likes: adyc
asiufy
Jul 8, 2011
3,604
573
485
San Diego, CA
almaaudio.com
#10
No, that's not what I wrote. I said the FIRST, not the ONLY one, that boosts dynamics. I never mentioned other products in the Gigawatt line, as, indeed, the PC-4+ was the first one from that line that I've heard. Others came later.
I'm sorry you misread what I wrote. I do get my facts straight, as I represent the brand, and very proudly so.
bonzo75
14,421
3,737
740
London
#11
That's already 7 to 8 recommended.
As long as we keep it in single digits
Likes: KeithR
Folsom
4,992
833
270
Eastern WA
#12
Fun factoid...
No conditioner has ever actually limited current unless it had a fuse that popped or a breaker that switched during playback. The reason a conditioner might have a socket with a lower current rating is because regular use would melt something. What does happen is with saturation of components not spec'd correctly for the current, is voltage drops that correspond directly with the music. It sounds awful when that happens. And it's rampant among a lots of products.
JackD201
Apr 21, 2010
11,644
621
660
Manila, Philippines
#13
Fun factoid...
Voltage fluctuations from the wall in general I might add. I remember throwing away my voltage display as it caused too much anxiety LOL That was a decade ago. I got tired of having to live with under and over voltage or waiting for when the nearby mall closed for the night.
I've gone battery.
LL21
11,413
397
628
#14
Interesting...are you concerned the Mephisto will have problems with the Torus? Years ago, i melted a power conditioner with my Antileon.
How can i 'know' that there is sufficient capacity in the Torus or any other such conditioner? Thanks!
Folsom
4,992
833
270
Eastern WA
#15
I've gone battery.
Well, when it's not tracking with the music identically, with lower and higher voltages in the same passage... (like with saturation) it's not nearly as offensive. What happens in our gear when voltage falls on its face you'll hear the obvious flatness to it! The capcaitors in the gear won't be able to charge, they just won't be able to maintain the voltage necessary. Where as a good PSU is designed to work on more than one voltage (a range near the expected voltage). 115v won't be likely to droop below what's needed for the music, even if 120v is the norm and it may go up to. Voltage regulation in and of itself hasn't proven to equal sound quality. It's usually the higher PSRR, lower noise, that stuff that comes along with voltage regulation that improves things.
1,590
720
#16
Torus has power conditioners with many ratings - the local distributor of Gryphon was recently using two Mephysto mono's with a Torus AVR 16 CE (230V /16A) and was very pleased with it.
JackD201
Apr 21, 2010
11,644
621
660
Manila, Philippines
#17
True, true. I like the part about flatness the best. Good way to describe it.
tima
1,787
1,283
390
the Upper Midwest
#18
Are you meaning to differentiate between power conditioners and power distributors? The thread title suggests you're not but your sentences speak to each. Most responses seem oriented to power conditioners. Granted that some products self-labeled as power distributors include some form of conditioning.
I'm interested in power distributors without conditioning. What criteria or feature set should one look for in a power distributor without conditioning? OFC outlets? Copper buss system or point-to-point? High gauge steel chassis?
Does adding protection such as an electronmagnetic circuit breaker and/or surge/spike protection impinge on dynamic current delivery? While some types may be filters, is the use of such considered power conditioning?
Likes: KeithR
1,590
720
#19
8(...) Voltage regulation in and of itself hasn't proven to equal sound quality. It's usually the higher PSRR, lower noise, that stuff that comes along with voltage regulation that improves things.
It depends a lot on the equipment and mains characteristics. IMHO we have not data enough to support the "usually". Unfortunately most (yes, almost all) people get conditioners without first getting a proper mains diagnostic.
analogsa
284
62
95
Cascais
#20
I agree. It boils down to one's interpretation of what sounds better. Personally i dislike any type of series or parallel filters and a large number of "well regarded" power cords too. Dynamic killers. Others dislike any form of voltage regulation within the equipment. It all boils down to personal preference and it's impossible to generalise.
Likes: cjfrbw
  • What’s Best Forum is THE forum for high-end audio, product reviews, advice and sharing experiences on the best of everything else. A place where audiophiles and audio companies discuss existing and new audio products, music servers, music streamers and computer audio, digital to audio converters, turntables, phono stages, cartridges, reel to reel, speakers, headphones, tube amplifiers and solid state amplification. Founded in 2010 What's Best Forum invites intelligent and courteous people of all interests and backgrounds to describe and discuss the best of everything. From beginners to life-long hobbyists to industry professionals we enjoy learning about new things and meeting new people and participating in spirited debates.
