ARC ref 3... what next?
Tim F
125
43
113
So out of the blue I have a buyer for my ARC reference 3. With some different valves in I was happy with it, except for the treble which just wasn’t quite bright enough (not far off). In terms of large scale imaging what would be the next step up?
I have a budget of <£5k and and will look for second hand. Also want something that I can sell on in the future so ideally not so esoteric that no one has heard of it. Rest of system is Auralic Aries Femto, Ideon reclocker, Lampizator GG2 and Focal Scala Utopia.
Thanks Tim
Direct Drive
148
141
115
East Anglia, UK
I moved from ARC (admittedly not a Refund, but LS series) to Leben RS-28cx....revelation. Soundstange was immense by comparison. No regrets. No need orvwant to change 3 years on. I appreciate your budget on basis of secondhand is greater, just a thought.
4,700
Thanks Tim
I moved from ARC REF3 to REF5 and improvement was mainly in articulation, treble and detail.
As far as I remember the V140 had only balanced input and were fully balanced - no input inverter stage - and need a true balanced signal.
Although more expensive than the REF5, an used ARC REF40 is a real bargain.
tima
5,842
6,900
1,400
the Upper Midwest
The cost differential between a used REF5 and a used REF5SE is around $1000. Having used both, I'd say the REF5SE is the better deal. ARC gear holds its resale very well.
Reactions: Pacha
4,700
Yes, the SE version is a significant improvement. But harder to get at a nice price!
Tim F
125
43
113
Thanks all, this is really helpful. I shall get looking! If anyone is UK based and has something good around the £5k mark let me know.
thedudeabides
2,162
669
1,200
Alto, NM
Consider the Conrad Johnson ET5 or later. A used 5 goes for $4K US.
ayreman
217
78
158
Ukraine
Thanks Tim
There is a much smarter way of spending your <£5k budget. Spend it on top-of-the-line parts and use them to replace the junk inside your Ref 3. As result, your modded Ref 3 will outperform Ref 10 (in stock) by a long shot. I've done exactly that. The result is otherworldly and totally beyond description.
thedudeabides
2,162
669
1,200
Alto, NM
Haven't heard the ARC. How does the CJ sound? Wonderfully musical. Read the reviews for the ET5 and later versions. I've found them to be spot on. But if you want a pre that has a pronounced top end bias, look elsewhere.
Tim F
125
43
113
Thanks, I don’t need too much warmth, neutral or bright would probably be best.
Tim F
125
43
113
Be great to get a few more opinions as there are so many experienced people on here. I may up my budget if something is worth it too.
