Aries Cerat...A Photographic Exhibition
Bobvin
1,315
1,956
330
Portland
www.purewatersystems.com
Forgive me… what is the correct pronunciation of “aries cerat?” Air-eaze, are-eaze, cer-at, ker-ate, cer-ought…
Audiophile Bill
4,179
3,780
575
UK
The subs he had in Munich 2019 were using the Foxtex Sigma, modded I believe in some way. This look basically the same but a wider version with an extra driver per sub. He really likes this driver as it is also used in the bass/lower mid horn of the
Bill , they are scaled up versions of the Erevus S series base horn utilizing three transducers per horn as apposed to the Everus S horns at Munich 2019 which utilised a pair per unit … An interview with Stavros recorded at the Munich show will expand on the subject
Thanks guys. Very interesting. I have no idea how they get it to function hornloaded into the low 20s with the Fostex Sigma since its fc is 42hz.
TheMooN
1,242
542
370
N/A
Good evening Bill , Without disclosing too much proprietory information Stavros touches on that subject from 1 min - 2.30 min in on the following …
Reactions: Audiophile Bill
Audiophile Bill
4,179
3,780
575
UK
Thank you very much! Have a great weekend.
Reactions: TheMooN
morricab
6,947
2,952
603
Switzerland
It's the same with a TQWT. The lower frequency of the system depends on the length of the horn and not the resonance frequency of the driver (within limits). My TQWT uses an 8 inch Supravox driver and it gets flat to about 30hz even though the resonance frequency is around 50hz.
Reactions: TheMooN
Audiophile Bill
4,179
3,780
575
UK
Reactions: TheMooN
orfeo_monteverdi
24
29
145
Europe
Even the Daft Punk duo does not have helmets as big as this one.
(very nice pictures BTW in the beginning of this thread, that I just discovered)
Reactions: TheMooN
MJG
21
91
170
59
Liechtenstein
TheMooN
1,242
542
370
N/A
A demonstration of the capabilities of the Aries Cerat Genus Integrated amplifier , 25W in Class A1, 40W peaks (Class A2) ,paired with a Kassandra Signature DAC, as always headphones if available.
Reactions: MJG
morricab
6,947
2,952
603
Switzerland
A demonstration of the capabilities of the Aries Cerat Genus Integrated amplifier.
WHat are the speakers? Very dark video...
TheMooN
1,242
542
370
N/A
Gahhhh , I very nearly went with the correct answer but changed my mind at the last second … He is driving Sonus Fabre Amati Futura, , Taiko Audio SGM Extreme completes the main box count, Signal Projects cable loom.
