Audience aR6-TSS vs aR6T-SSOX
MM622
18
2
3
#1
I’m using Audience aR6-TSS power conditioner a few years, I’m very happy with the performance this power conditioner. Now I can upgrade this gear to get a brand new aR6-TSSOX by paying about US$1920. However, I’ve compared it side by side at the same time, it seem like the sound quality is not significant between aR6-TSS and aR6-TSSOX. Have you compared it before? Do you think it si worth to pay this money upgrade to get the OX version? Any input please advise. Thanks.
Sablon Audio
Industry Expert, VIP Donor
May 22, 2015
613
159
43
#2
If you have already compared the two and felt the difference to be slight, then it is not worth changing. Spend the $2k saving elsewhere on more meaningful gains.
Sa683s
10
2
3
#5
According to my local Audience dealer said, Audience will release their new power conditioner AR6-TSSOXM in soon (M = Morre).
Does anybody test it before? How does it compared with AR6-TSSOX in sound quaility?
Ref:
http://audience-av.com/morre/
I hope I have time to pick up on this Saturday. AR6-TSSOX is already very good in my home, nothing restricted power etc. Music is more musical and live, only problem is it gives better power even with power amp plugged together! I need to re position my speakers and room acoustic to accommodate this power. So I’m very much looking forward to this “M” model.
Sa683s
10
2
3
#6
Only running for 2 days. Nothing stunning , only more smooth , more relaxing but it gives more power to amplifier than wall plug when connected all in the conditioner. Very similar to TSSOX version for now. Wait till it fully break in.
F2ECEA92-0E98-4B9D-9F1F-54CA13DFB2D9.jpeg 42E50CF0-B6DD-4956-8524-53F8FAC213B0.jpeg
restock
6
Toronto, Canada
#7
Very curious on your impressions on the TSSOX vs the TSSOX-M version - I just received a brand new TSSOX -M with the name now changed to aR6-T4 to mark the larger departure from the TSSOX.
Are you using it primarily with Au24 SX cables or the new frontRow power cords?
Sa683s
10
2
3
#8
Using 24SX, but I tried FrontRow. FR is surely a step above , its more detail compare to 24SX. I will buy FR if add one more power conditioner.
Likes: restock
restock
6
Toronto, Canada
#9
Thanks!! Have you tried the FrontRow vs Au24SX to the conditioner or also from aR6 to amps etc.? Also, have you tried any of the other FrontRow cables (IC, speaker)?
