G'day fellas,
Greetings from Melbourne.
Just wondering why there is no section for Avantgarde Horn Speakers?
Well it seems like I will be going around the roller coaster once again. I have paused on the Sonus Faber Elipsa Red's for a while, ( I was talked out of it)...
They are still gorgeous speakers to just look at...
Although I really don't like horns much compared to the seductive sound of electrostats, I figured that most horn systems I have heard are either driven with high powered tube amps or ss state amps exceeding 300 watts. The last time I had experience with Avantgarde Duo's and the Trio Classico, they were driven with 400 watt tube monoblocks from Melos (no longer made). After a few years the owner got rid of the Melos monsters and drove them with SET amps from Cary audio (just 18 watts). Then I realised that I do have mid-power amps with just 60 watts, and may go for a MC275 having just 70 watts. I listened to one system where the horns can be tamed, without that massive after ring tone that hurts your ears...
If powered just right, then the sound off Avantgardes can be truly special because they already have 250 watt built-in ss amps for the subs. All that is required is something of just 10 watts for the mid/highs.
Has anyone here had experience with the Duo series? I am seriously considering these, and the great news is that the Australian importer/service centre is located in Melbourne! close to my town.
Let me know your thoughts/suggestions on the Avantgardes, and anything I should know before I make a decision. I will be going for a demo next week, and will have an extensive listen to all models, including the Trio's.
Cheers, RJ
Cheers, RJ
