I have 7 sample packs ready to send to any Audio Tweaks Forum members who would like to try something unique and as yet unavailable commercially. I have checked with forum admin and it's ok to contact me via PM if you are interested. The tape will be delivered free of any charge including postage, worldwide. If you like it, there's a (small) chance I may decide to produce enough Batwing tape to offer for sale at a later date. For anyone who receives the sample pack, I will not contact you, ask for comment or bother you in any way.
The sample pack consistes of 3 sheets of Batwing Audio Tape, each 100mm x 80mm. This is enough to make a noticeable positive transformation of the sound of your audio system, whatever price or quality level you have. Suggestions for use are included in the pack. Instead of waxing lyrical about the positive effect of Batwing Audio Tape, I will instead list the possible negatives and shortcomings below.
The tape is highly conductive and can not be used as insulating tape.
The adhesive backing can leave residue on some surfaces if removed. The soft residue is easily cleaned off most surfaces if necessary.
The base material is weakly magnetic, so should not be used directly on phono cartridges.
You'll need scissors to cut the tape to size. One square cm is enough to make a noticeable difference if used in the right place.
After hearing what it can do in locations close to AC, you might be tempted to use the tape in dangerous locations. Please don't.
Thanks to our admin for making this possible.
Mark (Batwing)
Mark (Batwing)
