Being Installed on Friday!
Arcing will very quickly hole (destroy) gold plating. Arcing will happen every time you install or remove a plug with current applied (i.e. power switch on). However, that should not be a significant issue for a power plug IF the equipment is off when plugging in or out. There are a lot of very good reasons to NOT plug in (or unplug) a component with the power on, and that is one of them.
For musical instruments gold is not plated on brass as we want a harder finish underneath, thus gold plating is usually applied over silver. For electrical contacts, I usually see gold applied over nickel or chrome alloys as they are harder than silver. However, no matter the undercoat, an arc can wipe out the gold in the region of the arc.
Which is why I chose the Rhodium version...
I am installing the Rhodium version of the GTX-D this weekend... good bye Hubbell
i have 10 Furutech GTX-D Rhodium outlets in my system. they replaced Oyaide R-1's a couple of years ago. the GTX-D 'R''s are quite a bit better even than the R-1's. i was able to turn my tweeter gain up a notch on my MM3 speakers since the 'hash' from the R-1's was gone. better bass articulation, blacker backgrounds, more ambient information. i initially installed 5 and then compared the new GTX-D's directly to the R-1's. no contest.
drop the R-1's on a counter top and you hear a 'ring' as all the loose pieces rattle. the GTX-D's 'thud' on the counter top, solid as a rock. it's metalurgically better and mechanically better.
Thanks... Right, I compared the GTX specs with the R1's, and the latter still use a beryllium copper alloy, not pure copper. And the GTX clamping mechanism is ingenious, though not really worthy of a patent in my view.
the clamping system, with the stainless spring providing gripping power to the pure copper is a big part of what it does. also; it does not scrape the plating off your plugs like the R-1 did it gripped so hard.
Mike or Peter
Does Furutech make a 30 amp version of the GTX-D Rhodium outlets. I am noticing that it is a 20 amp receptacle
Haven't seen one
I haven't either and that is why I asked
Any recommendations on a 30 amp AC receptacle
Also, which of the Furutech cover plates are you using
I didn't order a cover plate. I will use the one I currently have that matches the rest of the decor. Frankly, I have never looked at 30A outlets. Call http://www.vhaudio.com and see if they can suggest something.
GTX installed, system warming up again. Lighter than the Hubbell, not as easy to loop the wire around the screws, but with a little extra effort it's not a big deal; didn't try the option to insert the wires in the back. Its grip is incredible, trying to unplug is an exercise in bras de fer! I did take an initial listen - who wouldn't - but I'll save my comments for later. All I can tell you right now is that I am thinking about an Equi=Tech 2Q next, for non-amplifier components.
Mike or Peter
here is my understanding of how it works.
it's the breaker and the wire that is significant in terms of rating.
The breaker protects the wiring, NOT what is plugged in. and A 20 amp duplex outlet has 2 20 amp outlets so clearly it is designed to handle more than 20 amps.
what i'm trying to say is that if your circuit is 30 amp rated a 20 amp rated outlet is fine. i've not seen different 20 amp and 30 amp outlets.
but i'm just relating my non-techie view of things. hopefully someone who actually knows about these things will provide a more credible answer.
I had 2 30 amp AC receptacles for my amps in my lady room. They were wired with 10 G Romex. I can't remember who made them
30 amp outlets are also single and don't come duplex.
i'm using the Oyaide WPC-Z Duplex outlet covers that i had been using on my Oyaide R-1 outlets. these were installed about 18 months ago. now there is a Furutech outlet cover on the market that i am told is even better 'sounding' than the Oyaide WPC-Z's.
It'll take a little time--just as rewiring does--to settle in also!
I'm just finishing my review--but in my system, the difference was night and day.
Frankly, I am not buying that electromagnetic shielding claim by Oyaide. I use a metal plate and I can't see how CFRP can better this. If nothing else, you use metal to build a Faraday cage, not plastic.
I'm going to remove Oyaide R1 with WPC-Z outlet covers and install Furutech GTX-D outlets with the Furutech plate and graphite covers this weekend if I have time. These outlets feed my two amps. Already have 2 GTX-D serving the front end. Chris at VH Audio also offers a 6 day cook on the outlets for $15. Well worth the money. The Oyaides took a good 2 weeks to break in. I didn't believe it either but you could hear them changing frequently over the course of time.
I also been using a GTX for almost two year's.
Once you have a good installation, it is a no look back option as far as I am concern.
Ditto but not optional. A necessity!
That is true as long as the wire is sized appropriately for the breaker. For instance, you should never wire 14/2 with ground to a 20A breaker.
I don't believe that is true. Both outlets from the duplex are wired in parallel. If either outlet or both combined exceed a 20A draw, the breaker will trip. You can't draw 20A from each outlet. There is only 20A available for both outlets combined.
