Adyc, stuff is always THE best. Until the next BEST thing.
With a $5k digital cable when is enough enough?
i was never confident enough that USB would be the long term interface to 'invest' in a high priced USB cable until now. i've heard how much better the MSB Pro USB interface is with my modestly priced USB's. now with the Gobel the delta is such that any other interface would be hard pressed to compete.
but only time will tell how long this seemingly huge advantage for USB in my particular system lasts.
right now all my 17tb of files are being transferred to my newly installed internal PCIe drives. so my listening quality is impacted for the next day or two. after that i will again comment on my progress with the Gobel USB.
Hi Mike.
I’m very surprised you didn’t research on USB cables with your digital electronic level. I have both Goebel USB and Ethernet for 2 years. As great the USB cable is i can assure you Ethernet one is even better.
Regards and enjoy !!!
of course, that is the rub.....whether USB? or Ethernet? or fibre? and if fibre?.....which fibre?.....which interface? combine fibre and USB?
all questions. with some answers now.
if i would have purchased an expensive 50 foot run of Ethernet cable when i preferred my Renderer i would feel a little frustrated right now. turns out the OM2 single mode fibre ($29.00) is better combined with the SPF modules. maybe the Gobel USB will turn out to be a long term keeper. but with digital i move slowly on that stuff.
i had decided a few years back that i would not chase expensive cables until i figured out which interface i was going with. i was tempted for sure. but i wanted to compare interfaces and not cables. interfaces are relatively cheap. cables.....not so much. so i stayed at modest levels with my digital interface cables.
until now.
on a related issue; this morning i remembered i had a 1m Sablon Panatela Reserva LAN/Ethernet cable i was not using. so i went upstairs and replaced the generic Ethernet cable between my fibre switch and Gigaswitch with the Sablon.
http://sablonaudio.com/index.php/signal
it's a slight bit better now.
might i try a Gobel there? maybe. but that (and a short Ethernet run from my now 'idle' NAS to the Gigaswitch) is the only place i can use an Ethernet cable now. otherwise i have fibre and the 1.2m Gobel.
Understood. It really has sense....
I would try the Goebel Ethernet. There is a lot of noise on that position.
Even i would put two Goebel PC on your mono Dartzeels.
The PC is another kind of animal. It is a beast !!!!
The Goebel sound signature changes a lot from digital to power and interconnects.
Each one sounds different in its position.
(...) in 1-2 years will the digital interfaces be different? it seems not as we might be at a maturing level of hifi digital interfaces. but nothing with digital would surprise me.
I warn all Goebel USB owners.
It weighs a lot and needs a support to avoid too much tension in the connector.
Mine has the connector slightly bent by the weight.
I know the feeling.My system doesn't want to play without Gobel cable
Glad you enjoy them. I have been using their speaker cables for a while and whilst they are not cheap they are only a fraction of the price of the top end cables yet to me possess exactly what I am looking for in a cable. I just wish they were lighter!I have tried to borrow expensive cables in Germany. That's almost impossible above 1500,- Euros. Then I came across Goebel. Since it's a German manufacturer, I was able to borrow the cables. And they are exactly how I always imagined top high-end cables, they are excellent. Now I am missing another XLR Stereo cable. I've been looking for a long time, but you rarely find these cables as used items at all. That's logical, because they are the last cables you buy.
