Cheap and natural sounding SPDIF RCA or AES/EBU cable?
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
I’ve ordered some Belden 9497 speaker, 1192A RCA and Gotham GAC-4 XLR cables to try instead of my Transparent Reference and Kubala Sosna after reading Tango’s and several other threads about natural sound and the use of professional cables instead of audiophile junk ones:).
Now, I also want to try an SPDIF RCA or AES/EBU connection between my Aurender and Lampi. What is the better option: RCA or AES/EBU? Could you recommend a specific digital Belden or Gotham cable?
Many thanks in advance,
Aziz
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
Aziz
If you look for a pro grade cable, I would add Canare LV-77S. Really good sounding, with the original crimp connectors. That would be a SPDIF recommendation.
Reactions: abeidrov
sujay
516
219
955
Singapore
I recently bought the Empirical Design S/PDIF RCA and am very happy. Excellent cable, cheap and way better than my previous Nordost Blue Heaven. In fact for the first time I felt the RCA bettered my USB on the lampi big7. The sound through the ED is meatier, with better dynamics and a wider soundstage.
Reactions: abeidrov
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Thank you all for the recommendations.
Out of curiosity I’ve connected my Gryphon VIP non-digital XLR to AES ports of my server and dac. It’s working:) I did a quick comparison to Sablon USB and the difference is really minor. I slightly prefer USB as it’s a bit fuller sounding. It should sound much better with a proper digital AES cable, shouldn’t it? Also, I’ve never used the AES/EBU ports, so it may be a matter of breaking in.
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
At this moment the debate between digital inputs is really coming down to the specific circumstances. How well are they implemented in the source/receiver etc. Just take your time and try it both ways, that would be my tip.
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Quick update: I‘ve bought DH Labs D-110 AES/EBU cord. It’s better than Gryphon VIP one. It is very smooth even compared to Sablon USB. Maybe a bit less resolving, but it could be an advantage. Interesting that I can play both DSD and DXD files through the AES port, Aurender must somehow convert them into lower res PCM, but I have not enabled DSD to PCM conversion in the Aurender settings.
Also, on some tracks the playback got interrupted, and I had to restart Lampi to restore the normal operation. Strange.
Reactions: jonathanhorwich
jep123
293
106
908
Norway
I am using the Mogami 2497 with KLE silver RCA between my CD transport and dac , a very good cable. I have changed all cables in my system from very expensive high end cables and I am now using only Belden 9497 and Mogami IC`s. Very happy and a lot of money saved. I am done with expensive cables, it is all a hype IMO. But, one must dare to try!
JP
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Has anyone compared DH Labs and Oyaide?
Thanks in advance.
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Just ordered Oyaide DB-510 SPDIF cable with BNC connectors, will compare it to DH Labs AES/EBU. Maybe the BNC connection will solve my 24/192 skipping issue.
rossb
68
40
148
I have recently replaced my Shunyata ETron Python AES/EBU cable with a cheap Van Damme cable I bought somewhere. It sounds better - much better. I ended up selling the Shunyata. I also have a DH Labs 110 ohm cable. The Van Damme cable beats it as well.
I have a bunch of Van Damme speaker cables and interconnects which sound pretty ordinary (I use Furutech interconnects and speaker cables), but the Van Damme digital cable is outstanding.
Reactions: abeidrov
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
I’ve just replaced a $8500 speaker cable with the one that costs $130 and I am shocked:) Our hobby is full of surprises :cool:
Pokey77
165
140
48
60
Would be interesting to know what $130 cable that is. Thx
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
christoph
4,674
4,071
825
Principality of Liechtenstein
DasguteOhr
2,419
2,589
645
Germany
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
And what was the other one? :oops:
Please, have a look at the first post.
I do not want to jump to any conclusions at the moment. I will continue using Belden and Gotham cables for several weeks and then switch back to my old ones. What strikes me now is how organic everything sounds. It is more noticeable with digital, where I use Belden RCA, than with vinyl, where I put Gotham XLR.
I think I am beginning to understand what other people mean by ”natural sound” :) .
Reactions: christoph
