CJ ART mono recommended ohm setting for speakers ....
joeinid
1,543
12
400
NY
According to the CJ website, the ART monos are wired at the factory by default for 4 ohms (they are also available connected for 8 or 16 ohm loads). My question is - Any typical speaker I am likely to use is 4 ohms, would there be any benefit to having them wire for 8 or 16 ohms instead? I thought I once read that they perform better wired for 8 ohms or 16 ohms regardless if the speakers are 4 or 8 ohms. Am I wrong and misread that somewhere or would it be in fact better to have them wired for 8 or 16 ohms. Any help will be appreciated.
MylesBAstor
81
1,725
New York City
No and better under than over eg 4 ohms for 6 ohm speaker. You're also throwing away power.
XV-1
3,619
2,629
1,860
Sydney
XV-1
3,619
2,629
1,860
Sydney
:rolleyes: Absolutely! and a GAT, again :)
Cool!!!
With your Tad's and Revel speakers the 4ohm setting will definately be best. If you were using them with your Klipsch, different story.
When do you get them? And are you selling off anything, or adding to your hifi store?
cheers
joeinid
1,543
12
400
NY
Thanks !
Dartzeel definitely stays, forever. We'll see about anything else. The jury is still out.
MarinJim
888
2
