Triode Wire Labs is gearing up for next week's New York Audio Show, September 9 & 10, to be held in Manhattan's Martinique Curio Hotel, 49W 32nd St New York NY 10001.
https://www.chestergroup.org/newyorkaudioshow/2022
We'll be in Room 409.
We're happy to be teaming up with Volti Audio and BorderPatrol Audio Electronics. Greg from Volti will be debuting his NEW "Razz-LE" loudspeaker at $6,500/pr. This Limited Edition version has clean lines and a fully finished front face, the Razz-LE is available in a variety of new finishes, including Crimson Red Poplar (to be at the NY show), Sage Green Poplar, Deep Blue, and Drift Gray Oak.
BorderPatrol will be featuring its BorderPatrol DAC S/SE-I, a non-oversampling, no digital filtering, resistor ladder (R-2R) DAC with a sophisticated tube/solid state hybrid choke input filter power supply, housed in copper casework. Plays files up to 24/96kHz. BorderPatrol will use its P21EXD power amplifier. A 20W/channel push-pull 300B power amplifier featuring inter-stage phase-splitter/driver transformers, point to point hard wiring and an external tube rectified a choke input filter PSU. The amplifier has no negative feedback and is housed in a copper and hardwood chassis. Both the amp and PSU’s have undergone extensive cryogenic treatments. With Western Electric 300B tubes.
We will be using an Innuos Music Server as the source and the entire Triode Wire Labs cable loom!
We will have libations of all sorts! Come thirsty!
Cheers,
Pete
