In another thread we came to the question of what considerations and experiments are made in the development of a turntable. Specifically, it was about the design of platters. In order not to deviate from the topic there, I was asked to open a new thread. Therefore, I would like to describe my point of view here and get your opinion.
Decisive for the sound quality of a platter is its vibration behavior. The less it vibrates, the less it disturbs the music reproduction. Of course, it is not possible to completely avoid vibrations. Therefore, the question for the developer is, which and how many vibrations do I allow. He has to decide which sound signature he gives to the platter and how many costs he causes.
The vibration behavior is determined by the parameters mass, damping and stiffness. From mass and stiffness results the natural frequency and the amplitude. The damping determines the period of oscillation. It would be ideal to achieve a very high stiffness for a small amplitude and a high damping for a low period of oscillation. But this is not so simple.
In most solutions, these two goals oppose each other. For example, if you want to improve the damping by using appropriate materials like soft rubber, you reduce the stiffness at the same time.
Here I do not yet want to explain how the corresponding choices affect the sound. I look forward to hearing your experiences.
Attached you will find a text I wrote for our dealers on this subject. Please do not mind that it sounds like advertising.
