Nobody in the rec.audio.pro newsgroup could recall the details of that loop-back test using high-end converters, so I did my own today with my mid-level Focusrite Scarlett ($250). I did ten sequential passes, with the last pass being a 10th generation copy. I used short excerpts from two different types of music - a classical string section and a pop tune. The four files are Original, Pass 1, Pass 5, and Pass 10, and each is about 5 MB:
Edit: To reach a wider audience and get more data, this is now a more formal article on my web site:
Converter Loop-Back Tests
If each generation sounds more grainy or "hairy" as was reported earlier with my SoundBlaster files, maybe some of you will be able to guess which file is which with this newer converter. However, I trimmed the file lengths slightly to be sure that will not give you a clue.
I'll be interested to see how many people can discern the various generations from each other and from the original. Especially Bruce. But please folks: if you don't state your guesses before I post the answers in a few days, do not post later that you could tell which is which!
--Ethan
--Ethan
