I have 1.5's under all of my power supplies and yes it makes a big differenceI own a Lumin X1 and have underneath it the CM2 1.5 footers.
Now I wonder if also placing a set underneath the separate power supply would also be a benefit.
ozzy
Under the N30 chassis first and then the power supplyGood question?
Not to hijack your thread, but I have a similar dilemma.
Is it better to put the CM footers under my Aurender N30 control chassis or power supply chassis?
Only have 1 set.
its also best to start with the source and follow the signal with amps being last and then power suppliesAlways place the CS footers under the mains first and power supplies last
Seems like an easy thing to try. Put the footers under the PS and listen. Then move back to Niagara and see which one you like best. Only your ears can tell you which one is best for you.So, since I have a set under my Lumin X1 and another set under my AudioQuest Niagara 7000 are you saying it would be better to place the set under the Lumin power supply instead of under the Niagara?
ozzy
Time to get the bicep readyI will but remember the Niagara weighs 90lbs. So not so easy to go back and forth.
ozzy
Another reason for the Lumin Ps to be firstI will but remember the Niagara weighs 90lbs. So not so easy to go back and forth.
ozzy
FWIW it is also very easy to place under the power supply and evaluate for a few weeks and then place them under your other component. I still feel power supply will give better resultsThank you. That's what I will go with.
ozzy
