FYI to anyone interested in Cybershaft products; in addition to the new higher priced offerings with the option
to utilize either power from the wall or an external linear regulated power supply...
http://www.cybershaft.jp/a-products/op20a.html
and single output clocks;
http://www.cybershaft.jp/a-products/op21a-1.html
Cybershaft has also just made public on their website lower price options that don't sacrifice great baseline performance;
http://www.cybershaft.jp/a-products/ocxoma1.html
For non-Japanese speakers...
Open in Google Chrome, look on the list of selections on the left hand page and select
"For Overseas (English)"
will take you to;
http://www.cybershaft.jp/overseas01.html
Any questions, let me know.
You can also send email directly to (note there is only 1 working email address now);
Cybershaft777@yahoo.co.jp. [NEW / ONLY email address that works]
Any questions or problems getting in touch, send me an IM and I'll help wherever I can.
Multiple Output Versions (option to use built in power supply or have model that uses external power supply)'
Model number: UPOCXO-OP21A Model with built-in AC power supply
Model number: UPOCXO-OP21A-D External DC dedicated model
Model number: UPOCXO-OP20A Model with built-in AC power supply
Model number: UPOCXO-OP20A-D External DC dedicated model
Model number: LTPW01P External DC power supply (with panel)
OP'XX" or in this case, OP21A or OP20A is the performance level of the OCXO. OP21 is a touch better in principal than OP20A, differences are minor
Single Output Versions (only use external power supply);
Model number: UPOCXO-OP21A-1 External DC dedicated model
Model number: UPOCXO-OP20A-1 External DC dedicated model
Single Output / Lower Precision (OP19, 18, 17, 16, 15, 14, 13, see table below on that page rating and price option), this line reads like it is meant to be more economical choice;
Model number: UPOCXO-MA-OPxx External DC dedicated model
Model number: LTPW01P External DC power supply (with cast panel)
There are products (clock distributor) and other prior products.
Note I'm not listing all legacy/prior products above, only the newer ones.
They have a line of products for each need and multiple budgets now.
That's how I read through the plethora of options now available.
Hope this helps...
will take you to;
Hope this helps...
