Dartzeel NHB-18NS or ARC Ref 5 se?
Cascais
257
2
150
Can anyone compare these two fine preamps? I am using the Ref 5 se with a Dartzeel NHB 108 power amp but have an opportunity to acquire the NHB-18NS which I would probably have upgraded to new status. Note: I am perfectly satisfied with the Ref 5 se but you know how temptation is.:p
XV-1
3,591
2,573
1,860
Sydney
Go for it. I don't believe you will be dissappointed.
Mike Lavigne
Apr 25, 2010
12,467
11,363
4,410
I have no personal experience with the ARC Ref 5 SE; however I live every day with the new dart NHB-18NS preamp and it's is astonishingly good in every way, and the previous unit I owned for 9 years is very very good too.
do it!
etunes
64
25
925
Virginia Beach
I've owned both the ARC REF 5,5SE and the older Dart and now the newest version of the NHB-18NS. My amp currently is the Dart 108. I much prefer the Dart and there is great synergy between the Dart pre and amp. Sound wise for me they are very far apart. I find the Dart much less fatiguing and more musical but results may vary.
Cascais
257
2
150
Since there are no reviews yet to my knowledge of the revised NHB-18NS, could you describe the difference you found between the old and new version of that preamp? I am having a problem connecting with Hervé as my emails keep getting kicked back.
ashandger
406
174
348
I believe Fremer is going to be publishing a review of the revised Dart soon....I think he makes a reference to this in his ARC Ref 6 review. Could be worth sending him a message on his own website. Please let us know if you get any feedback from him on the publishing date.
etunes
64
25
925
Virginia Beach
Battery works and is easily switchable for critical listening sessions. Couldn't tell the difference for a long time but it has come into its own and adds another layer of air and finesse . The phono stage is also adjustable and while I haven't heard many stages this one is really good as good or better than anything i've heard. Volume adjustment is not quirky like some of the older units. Sonically it just gets out of the way no longer evaluating gear performance just enjoying music....
Cascais
257
2
150
Thanks for the information. In his recent review in Stereophile, Fremer describes the ARC Ref 6 as close in performance to his reference NHB-18NS. It's not clear in the review whether he is using the old or new version darTZeel, a problem since the name's the same.
Cascais
257
2
150
Thanks very much for the reply. Seems as if the difference between the two versions is not stunning but is worthwhile.
ashandger
406
174
348
He has had the new version of Dart for many months now so I strongly suspect it's the new version. I am sure he will refer to the ARC Ref 6 in his review of the new version. I recall reading a comment from him somewhere that the new version of Dart was more transparent than the old version.
Cascais
257
2
150
I hear from Geneva that the program to convert the old 18NS to the new version specs is now underway in three steps. It isn't cheap but it is good value for money with flexibility.
4,698
I'd say it is a stunning change to my ears. however; it's also somewhat system dependent as far as the degree of perceived change.
My sources who own the new preamplifier confirm your opinion, but I have not listened to it yet.
Cascais
257
2
150
Today my NHB-18NS is being shipped to my home near Lisbon thanks to the encouragement received from this thread. The supplier included a pair of BNC Zeel interconnects for between the preamp and NHB 108B which I will try in place of the balanced interconnects presently in that position. If I prefer the Dart to my present ARC Ref 5 SE, which I expect to be the case, I'll use it as is for a while in the old configuration and maybe in the New Year send it to Geneva for surgery.
Argonaut
2,380
1,615
530
N/A
Cascals.....Congratulations on your new Pre amplifier, I do like Dart equipment, however I feel that I should highlight the obvious disparity in RRP between the two units in question, perhaps a comparison with an ARC 40 Anniversary or REF10 might be a somewhat more level playing field than an Ref5 SE, particularly if the latter is sporting factory Sovtek valves ( A number of threads here regarding the regulator 6550 in ARC Ref gear)
Cascais
257
2
150
Thanks for the kind words. While considering the move to Dart, I changed the ic between my emm Labs CDp and the Ref 5 se to Kimber Select KS 1136 from the hybrid KS 1126 with astonishing results, sounding like I already had upgraded the preamp. This much improved sound is still in my system so it will be interesting to hear where the 18NS fits in. Of course you're right about the superiority of the Anniversary and Ref 10, even the new Ref 6. But I want to go back to solid state from tubes. One advantage of the 18NS is the built-in phono stage which will make some of my equipment superfluous.
4,698
You must consider this swap with an open mind and be prepared to make some changes in your system to get the best of the Dart system. The two preamplifiers sound very different.
Argonaut
2,380
1,615
530
N/A
Quite understand your reasoning Cascals, built in phono being rather persuasive, good luck.
Cascais
257
2
150
If the system with the addition of the Dart preamp is not as satisfying as with the Ref 5 SE, I will probably stay with the ARC based system which is very satisfying.
Cascais
257
2
150
By all accounts it is a very good phono section, comparable to some very expensive stand-alone models. See the comments in Stereophile and 6 Moons.
