So I had a client make a understandable mistake. He hooked a Switch X directly to a cable modem and hooked his server and renderer to the switch X. The switch X has NAT so worked like a router no problem.
He tried to hook his house to the other port on the Arris S33 modem. This did not work.. I explained that cable co's only give you one IP for residential accounts and so you can only have one device connected.
He rearranged things and did cable modem S33 > Home router > Switch X > Audio gear..
He reported that his sound quality with the Switch X hooked directly to the modem with nothing else in the house hooked up sounded much better. It was still better then his prev switch, but the dedicated modem hook up was amazing..
So I just tried that myself. I have not only a S33 but I also have AT&T fiber. So I played with both fiber and docsis ( cable )....
So, he is right, a dedicated setup with its own modem is best for sure. WHY is a hard question to answer technically.
I also found that there were differences in fiber VS copper ( cable ).. SUrprizingly the S33 sounded better then the fiber BGW320-505. Which is not what I expected as the latency on the fiber connection is way better and jitter is lower. Not to mention the fiber modem is isolated. I feed both from old school restored Lambda linears.
So I wanted to post about this because if your serious about music rendering you should explore a dedicated connection VS plugging into your house network.
Others must have done this already right ? I just had not heard of anyone doing it.
