Does Anybody Hear a Difference Between Ground Coffee and Instant?
16,215
13,692
2,665
The coffee table question got me thinking. What about the coffee on the table? (Well, in the coffee mug on the table.)
Might ground coffee resonate to the music differently than instant coffee?
Is one type of coffee better for certain kinds of music than the other type of coffee?
Do you think the ground coffee, because the coffee grounds are less uniform, might be better at diffusion than absorption?
Should the coffee mug be placed on an isolation platform?
RogerD
3,734
319
565
BiggestLittleCity
I need to star ground my coffee grinder,it is really noisy.:D
wisnon
3,536
640
1,200
Coffee from the Blue Mountain peak has more "air" around it.
bonzo75
22,643
13,675
2,710
London
If anyone bothers about a coffee table, music is not his cup of tea
jackelsson
264
216
355
.de
If the coffee has been treated with a proper grounding, umm, grinding device the negative side effects should be minimal...
DevAAudio
109
56
95
So I am new to this forum and am an avid coffee drinker. Having recently returned from a family vacation in Italy, and given my own personal experience with hand crafting espresso beverages in my home, I feel like I am qualified to express an “expert” opinion on this topic... :).
Instant coffee is a bad idea. It will put you in a bad mood prior to sitting down and enjoying a relaxing music experience. A properly crafted and slightly well bodied coffee fits the bill. Tasting the different “notes” within good quality coffee beans can enhance your critical listening experience. Placing the coffee on one of the newer hot plate devices that keeps the beverages nice and hot will also enhance your listening experience. Depending on decibel level and bass response in your room you would want to be careful not to overfill your mug to avoid accidents and seepage down the sides. This is when an isolation platform may actually have some benefit! Will have to try that out. Maybe an HRS nimbus assembly as a coaster! (LOL).
Looking forward to corresponding with you all... Cheers!
-Deva
16,215
13,692
2,665
Welcome to WBF!
Folsom
6,032
1,503
550
Eastern WA
I dunno, is that hot plate isolated from the stereo's power?
cjfrbw
1,358
1,730
Pleasanton, CA
My rotgut caffeine vehicle doesn't come alive with less than 400 watts class A.
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
-Deva
Great first post Deva. :cool:
Tango
4,938
6,269
950
Bangkok
-Deva
Dear Sir,
If you were to replace your Stage III with the Siltech Tripple Crown from wall to the coffee machine and also ground the coffee grinder with Tripoint, your sipping/listening experience will highly be elevated.
Kind regards,
Tang
GMKF
432
86
135
Munich
Dear Sir,
Kind regards,
Tang
I recommend custom roasted coffee, to fit your taste. I have 4 different coffee beans. If you want to tweek it a bit use mineral water.
4,702
Dear Sir,
Kind regards,
Tang
We should not forget about the absolute need for balanced power - lower leakage current is a must in a grinder.
Hi-FiGuy
2,242
763
385
Coffee with Bourbon in it extends the sound stage far beyond the rooms boundaries, the veil never existed, and the resolution is beyond comprehension!
cjfrbw
1,358
1,730
Pleasanton, CA
You'll need balanced cables to keep your coffee grounds lifted?
Gregadd
1,790
1,850
Metro DC
Post deleted
Political in nature, off topic
