I tried to power on my Oppo the other night in anticipation of watching a DVD. It wouldn’t power on. Not with the remote and not by manually pressing the power button. After contacting Oppo support and following more than the usual instructions to restore process to my Oppo, nothing worked until I was instructed to plug it into a wall socket. After a few days I returned it to the protection of my Brick Wall, a line conditioner and surge protector that cost me nearly $600. It is advertised to never fail
And as a line conditioner
It has 8 receptacles in the back and two in front. I’ve been very happy with it, especially its large number of receptacles, 8 behind and 2 in front.
I then brought out an ordinary power strip/surge protector and the same thing happened; the Oppo failed to power on.
Coincidentally,, I bought a new Roku and when I plugged it into the Brick Wall, it failed to display its menu. I plugged it into a wall socket and no problem, it displayed its usual menu. I plugged it into the power strip and it refused to display.
I wrote to Oppo and asked them why they had told me to plug thr Oppo into a wall socket. They replied that they had had some problems with surge protectors and didn’t know why.
I also have my ARCAM SR-250:AVR out for service becsuse among other things, it wouldn’t power on. The service department where I sent it reports that it operates perfectly. Now I’m wondering if it is having the same problem as the Oppo and the Roku.
I should add that I’ve tested all the sockets on the Brick Wall and the power strip and all will turn on a lightbulb and I’ve also plugged in a power saw here and there and it works just fine too.
But what is causing this problem???
No Failures - Period | Brick Wall
Brick Wall Surge Protectors Do Not Fail Tested to One Thousand Surges of 6000V, 3000AWe believe that surge protectors should not fail. At the heart of o...
www.brickwall.com
Line Conditioners | Brick Wall
Brick Wall Surge Protectors are Exceptional Power Conditioners System NoiseElectronic noise is undesirable low level high frequency signals found on the...
www.brickwall.com
