Anyone here have experience with the EMT STX 5/10 transformer?
https://www.emt-tontechnik.ch/electronic/EMT-STX-5-10
That SUT sounds really good. Silver transformers are made by Audio Consulting. Step up ratio is low and you need a cartridge that outputs at least 0.5mV.Anyone here have experience with the EMT STX 5/10 transformer?
What cartridge do you hear it with.That SUT sounds really good. Silver transformers are made by Audio Consulting. Step up ratio is low and you need a cartridge that outputs at least 0.5mV.
As far as I remember a couple of EMTs, one or two ZYX 4D cartridges.What cartridge do you hear it with.
There is one of the inputs labeled "EMT", just plug into it and enjoy the magic. Every one of our EMT's sound magnificent with the SUTI will be using various EMT cartridges.
I use it for a few of our phono stages. Typically it goes to the Nagra Classic Phono, but I have also use the Phasemation EA-550, Gold Note PH-10 and Vertere Phono 1 in the past couple months.You use one?
What phono is it going into.
