Fixed Placement, Fixed Sound
Ultrafast69
222
227
385
Seattle, WA
www.audio-ultra.com
Speaker placement is paramount, but is it ever left to be fixed and never move?
Fractions of an inch can change things radically from my experience.
I have moved speakers matching changes related mainly to power changes.
How many others have moved their speakers when it comes to change?
Reactions: MadFloyd
PeterA
12,684
10,948
3,515
USA
Speaker placement is critical. After changes to my system I usually re-examine speaker placement. It’s all about finding the right balance for your subjective preference. Cables, power cords, cartridges, they can all slightly change total balance and so I often adjust with speaker placement. As you say, tiny changes in position can make a difference. It helps to have a reference and specific goal in mind.
4,702
Speaker position is critical, but I do not re-adjust it for compensating recordings or equipment choice. I usually carry it with the most "neutral" system I own - the QUAD 606 amplifier and the DCS Vivaldi using all Mogami cabling. Then forget about it for a long time - probably until I want to listen to another speaker in the room.
bonzo75
22,643
13,675
2,710
London
I am sure speaker placement is important given how many threads we have running on the topic concurrently
dan31
1,019
369
1,653
SF Bay
I just went through a speaker adjustment. Maybe 2 cm forward and 1 cm out. Nice adjustment to tonal balance and separation of instruments. Sometimes we need a little adjustment to reconnect. .
Kingrex
2,943
2,409
350
I fiddled with mine today and the blur I have is gone.
Macattack
222
144
395
SC Low country
I recently went through a two step change in speaker placement and have the best sound I have ever had. Movement towards each other and about 1/4” more toe-in.
Speaker placement is everything relative to your listening position.
christoph
4,679
4,072
825
Principality of Liechtenstein
And those two relative to the room ;)
That makes a LOT of variables for setting up a system in a given room :p
