Up for sale we have a beautiful FM Acoustics 811 MKII amplifier. This amp is in like new condition and was serviced in 2015 by FM Acoustics in Switzerland. We had FM Acoustics install the new LED lights like the 1811 has (replacing the older style light bulbs that burned out often). This amplifier performs flawlessly and has only been serviced by the factory. It will include a 3 meter pair of FM Acoustics Forceline 3 speaker cables as well. We have had many FM Acoustics amplifier which include 411 MKII, 611x, 711 MKII, 115 monoblocks etc. This is by far the best of them all. We are selling this amplifier for $64,000
A Few Specifications
Minimum Power Output:
900 W peak into 8 Ohms
1700 W peak into 4 Ohms
3000 W peak into 2 Ohms
455 W RMS into 8 Ohms
850 W RMS into 4 Ohms
1500 W RMS into 2 Ohms
Max. Output Voltage: 180 V pp.
Max. Output Current:
Absolutely unlimited peak current.More than 60A continuous per channel allows the FM 811 to drive any known load without any negative influence on the audio signal. No fuses, absolutely no form of current, voltage or any other kind of limiting.
Distortion: Average distortion: 0,005% THD
Gain: 30.5db
Bandwidth including Input Filter: (-3dB)
1 Hz to 60 kHz.
If required, internally settable to any frequency between 1 kHz and 60 kHz (Low-Pass) and
1 Hz to 1 kHz (High-Pass).
Risetime at Full Power: 3 us
Hum and Noise: (20Hz-20kHz).
Below full power typically: -115 dB
Min. unweighted: better than -100dB
Input Sensitivity:
1,2 V RMS for full output
Input Impedance:
At all level settings from balanced and unbalanced sources: 40 kOhms
Input Stage Common Mode Rejection:
100 dB typically, better than 90 dB at 50 Hz, even better at other frequencies.
Load Impedance:
No minimum impedance. Designed for 1 Ohm to 10'000 Ohm systems. Can drive any speaker impedance (even below 1 Ohm) with dynamic (music) signals without any limiting, compression or other negative effects on the audio signal. Despite this, the amplifier is fully protected against short circuits, open circuits and all other adverse conditions via a unique onboard computer that continuously surveys all important parameters.
Gain: 30.5db
1 Hz to 60 kHz.
Input Sensitivity:
Input Impedance:
Load Impedance:
