Wow Mono and Stereo is totally unreadable anymore.
Very interesting speaker, want to know more but not with all that other crap going on around it.
Yes please we need some show pics and opinions.
Here is the preliminary information about the Divin Marquis. The speakers will be delivered in Mid April and we will try to show them as soon as it is possible here in Florida. I do plan on making some videos about the speakers after they arrive so that everyone can see what Oliver has created. We also will be taking orders for future and current production,
We were able to transform the awesome sound qualities, the outstanding and unique technologies and design properties of the Divin series to a smaller foot print.
To name a few of the unique technologies and key design properties:
- We use the same world wide unique 8 inch midrange chassis, which is enhanced through our bending wave technology, as we use in the Divin Noblesse and in the big Divin Majestic.
- We use the world wide unique 12 inch long throw bass chassis in a 8 ohm version, as we use in the Divin Noblesse.
- We use a heavily modified AMT tweeter, coupled to a big wave guide, with a perfectly adjusted tractrix curve progression, milled out of full aluminum, as we use in the Divin Noblesse.
- We use a constraint layer damping enclosure construction with tropical room proof resin bounded enclosure material with kinetic mass damping on special locations of the enclosure, as we use in the Divin Noblesse.
- We use the same symmetrical bass reflex arrangement enclosure in order to minimize distortions as we use in the Divin Noblesse and in the big Divin Majestic.
- We use the ceramic foam coupled internal helmholz resonators in order to totally control internal enclosure resonances, as we use in the Divin Noblesse and the Divin Majestic.
- We use the same proprietary stainless steel feet, which perfectly couples the enclosure to the ground through big Siliciumnitrid ceramic balls of the highest quality, as we use in the Divin Noblesse and in the big Divin Majestic.
- The crossover parts are of course also top notch from Mundorf and Duelund with multiple in house epoxy resin vacuum impregnations, as we use in the Divin Noblesse and the big Divin Majestic.
- The time and phase behavior over the complete frequency response is excellent, as it is within the Divin Noblesse and the big Divin Majestic!
- We could achieve a high real sensitivity of 92 db / 1 W / 1m.
- Also the impedance behavior and electrical phase behavior is extremely even, so it can be controlled and driven by nearly any amplifier!
- For the best possible finish, we of course use the same real piano polyester lacquer highest grade made in Germany, as we use for the Divin Noblesse.
The technical specifications:
Principle: 3-Way, high sensitivity, symmetrical bass reflex loudspeaker
Driver: 1 pcs. Göbel® High End proprietary longthrow Bass chassis (12 inch), 1 pcs. Göbel® High End proprietary midrange chassis (8 inch), significantly improved Mundorf AMT with massive aluminum wave guide
Housing: Acoustically optimized, constraint layer damping, tropical room proof, resin bounded composite board with max. 75 mm thickness
Standard finish: Real piano lacquer black, aluminum parts in black ultra matt soft touch with silver colored high lights. Any finish is possible on customer request!
Sensitivity: 92 dB / 1W / 1m
Frequency response: 21 - 28.000 Hz (-3dB)
Impedance: 4 Ohm
Dimensions: 118 cm (H) x 41 cm (W) x 72 cm (D)
Weight: 150 kg without packaging
