Based upon what you have for your arm and actual viewing…..
Re: My own CA-7 10 …..
The engraved alignment marks are not parallel to the cut perspex long edges and are thus also slightly of angle against square to the aluminium bracket…[cantilever will be at an angle to square] [not parallel to the aluminium bottom and not 90 degree to the upper]
Based upon looking at your own CA-7 10….is this correct ........or do I need to correct it to be square to the Frame and holes for the arm [manufacturing error]
…easy to do by re adjusting via the screws…
Am aware that the CA-7 is arm length specific…my 9 engravings are parallel
Have asked Bob…appreciate he is busy……
