"Grunge"
stellavox
284
61
1,583
I want to comment on the aspect of “grunge” (alternatively called RFI or EMI or ...) creeping into a playback system from the outside. I’ve experienced it directly at home, at a friend’s, and have read of many anecdotal problems. Don’t know if this is the proper forum but from a cursory inspection of other forum threads it hasn’t been mentioned anywhere else – so here goes…..
From just its impact on audio reproduction we live in a VERY polluted environment. “Grunge” can be borne into or generated within your home and conducted through the power wiring - acting as an “antenna”. Or it can just flow in through the walls in the form of electric and/or magnetic waves (transmitted).
The effects range from severe to “unknown”. A few years back, a friend was trying to assemble a system on the second floor of his house and try as we might we couldn’t get an objectionable level of “hum” out of his phono hookup – it worked fine downstairs however. On my current system, if I put my tape pre on max gain and turn the volume all the way up I can (sometimes) faintly hear a local radio station. One of my customers had the same problem but much more severe. A potential customer was experiencing an objectionable background “buzz” from the combination of my preamp / his deck. I added the word “unknown” in the first sentence as you may be experiencing a problem and not even know it – yet “something” is or feels wrong.
I want to separate out conducted from transmitted “grunge” for the purposes of how it can get into your system. It gets "conducted" through the power cords; it gets “received” (opposite of transmitted) "through the air" by potentially ANY system component – even your speakers.
The electric power system is supposed to generate and “conduct” current alternating at the rate of 60 hz. Fluorescent lights and (the many) switching power supplies in your home, not to mention the variable speed drives of your “next door” machine tool company generate higher frequency harmonics that can make it into your home and be conducted right into your system components. Commercial radio and television installations (which are pretty easy to spot) and cell phone installations (which are not) produce electromagnetic radiation.
How can this “grunge” get into a component and what effect can it have? Even with some kind of power line filtering on the input of a component, conducted high frequency components could make it into / through? the power supply and perhaps “modulate” the downstream supply voltages. Received electromagnetic waves are insidious. They can get in through any “antenna” which includes input or output cabling – or even a ventilation hole!. Once inside, although the frequencies of these waves are typically many orders of magnitude higher than what our ears can perceive, they can be “demodulated” or “rectified” down to a perceivable level by various internal parts or interconnections.
I realize that all kinds of ink has been spilled on this subject. There are MANY references to specific kinds of interference and its mitigation. There are a number of products designed to “sniff out” conducted problems – detecting electromagnetic problems are another matter. My own feeling is that if you live in a metropolitan environment, because of the high probability of “dirty neighbors” your system may very well be “swamped”. How is it responding? Let’s discuss this – what problems and solutions have you experienced?
One final thing I want to mention is the actual impact of “tweaky” accessories on grunge. Certain esoteric accessories, especially metallic ones, seem to produce improvements in certain listening environments. Manufacturer’s claims or questionable explanations aside - their effectiveness could be due to their configuration and specific placement in a room. They could actually be “shunting” very high frequency electromagnetic waves away from one or more susceptible components - in effect acting like a low pass filter. A case in point; my friend whom I earlier mentioned had “hum problems upstairs” (which we did trace to a line-of-site radio station tower) found that some current tweak, a little length of ‘wire-type” product that you hang from your speaker terminal, seemed to sound better. Another correspondent who tried them realized no improvement. Maybe the accessory actually mitigated waves in one room that didn’t exist in the other.
Charles
MylesBAstor
81
1,725
New York City
Charles
I remember a customer bringing back an old PS Audio preamp to Stereo Exchange because it picked up Channel 2. Seriously...So it would seem that one needs to pay attention when dealing with ultra-wide bandwidth designs too :)
Another one of my friends had this dumb Ham radio operator with an antenna on the roof of his building (Probably an illegal set up too). Every time this jerk broadcast, he broadcasted too through the building's AC line and would come blasting through his system and speakers. Nothing my friend did, including all types of ferrite beads, etc, could stop him. Eventually a baseball bat did :(
Then another reviewer I know swore that having the old cordless telephones in the house affected the sound of his system. As you say, one wonders with all these cell phone towers, etc., how much that affects the sound.
Finally, the sound of another audiobuddy's system changes from hour to hour. It seems that one doesn't want to listen esp Sun. morns when everybody is up and has every electrical appliance on. And he's done everything he can to no avail.
mep
17
Since this forum has so many resident geniuses, I would like to see someone write an article on a really good grounding scheme for our systems. Copper ground rod outside with copper ground line run into the listening room attached to a copper ground bus bar to attach all of the components to? Something that is practical, doesn't look heinous, and that will work to knock out hum nasties.
I have a new member joining our panel of experts hopefully this week on that very topic
FrantzM
29
405
mep
Not a genius but an EE in Telecom who was forced to know a thing or two about grounding and power quality when I had to provide 24/7 mission critical communications series to customers in a country where the commercial (Government-owned of course) electrical grid provides at best 40 hours of power a WEEK!!!...
Power Quality is a real issue and as I have repeated countless of times, addressing it improves one's system. grounding is an element of Power Quality, not the only one but it is essential. A very involved and complicated subject ... there are some relatively simple solutions... maybe later...
stellavox
284
61
1,583
mep - there's no one answer
mep: Thanks for your comment. It raises a good point that perhaps I should have mentioned.
There is no one "cure-all" because there are different problems. APART from grounding and ground loop-related problems - problems which may be caused by and only exist WITHIN your system, there are other problems related to "grunge" coming in from the outside world (WITHOUT).
Attention to good grounding practices, like Doc alluded to in his recent tape head posting, should be able to solve the "within" problem - perhaps someone has another "favorite" reference they can pass on. With regards to transmitted or radiated grunge, one sufferer I know was only able to eliminate / significantly reduce the effect of a nearby radio tower by creating what I believe is referred to as a Faraday Cage - effectively creating a shielded box (grounded in some manner) within his equipment rack to house sensitive equipment. Regarding reducing conducted grunge - dedicated branch circuit from the breaker panel / line filtering / AC regeneration / balanced power / battery power - are all methods which have worked for various individuals.
stellavox
284
61
1,583
Myles,
Channel 2 on the preamp - brings up another point - in the military I believe it's called "EMI susceptability" or something like that. There are strict MIL (Military) specifications relating to this. They involve placing a piece of equipment in a shielded room (to minimize radiation from the outside), get it operating correctly and then subject it to all kinds of intentionally generated conducted and radiated intererence to see what happens. I think it is safe to say that this is never done in the commercial product world - until a priblem arises. I'd like to think that audio designers are aware of these potential problems and incorporate some protective measures in their design.
Let me apologize for the dumb ham radio operator. I'm one; K1ETU, and have offended so I know what it means. Most of our fraternity and it's guiding body (the ARRL - American Radio Relay League) will do whatever it takes to eliminate neighbor's problems.
System sound changing with time of day is not uncommon - a fellow on our audio society website has that problem now - at night which IS uncommon. Having a problem on a Sunday morning is God's way of telling your friend to go to church!
MylesBAstor
81
1,725
New York City
Didn't someone once talk about constructing a room with copper screening in the walls to shield from outside interference? Certainly the early MRI machines had to be built in shielded rooms :)
FrantzM
29
405
One could listen in a Faraday Cage the problem of EMI/RFI coming from the power lines remains whole.. Some power supplies deal with it very well most don't ... Another problem are indeed as the OP mentioned, EMI that are generated inside your istening room.. Dimmers for one are serious offenders but also many digital components..
more later ...
MylesBAstor
81
1,725
New York City
more later ...
Dimmers are certainly a problem. Every one that I've ever heard adds a brightness and harshness to the sound.
I've even found that the display on my digital playback gear affect the analog playback :) My DAC and transport allow for both displays to be turned off.
Andy
7
North of Seattle
I had sold some variacs on ebay to a company that housed them in wall mount panels to make dimmer switches for recording studios (to eliminate noise)
edit: out of curiosity wanted to check to see if the company was still in business (I have no affiliation) and he is still selling on ebay, not sure if it is appropriate but his userid on ebay is davidriddle,
Mike Lavigne
Apr 25, 2010
12,587
11,663
4,410
great subject.
twice recently in my system i was able to observe the before and after of 'Grunge'. in retrospect; it's clear (pun intended) that you don't really appreciate what 'Grunge' is until you hear the effect of it's absense.
last fall Rich Brown brought the King/Cello repro unit over to my place for the first time. Ki Choi had wired in a switch on my Studer heads so we were able to A/B the system easily thru the stock Studer electronics and then the King/Cello. most noticable with the King/Cello was the absense of this cloud of grey 'grunge' veiling the sound. i was only able to identify this characteristic when presented with it's absense.
at that point there was still work to do with the King/Cello before it was ready for prime time in my particular system; but it was easy to see we were going in the right direction. the 'grunge' in this case was likely both 'recieved' and 'transmitted' from the 'active environment' of inside the A-820. the isolated power supply and gain stages of the King/Cello removed much of the crud.
a couple of weeks ago i installed the Equi=tech isolation transformer. it has a stout double ground rod and is balanced for common mode noise rejection. big difference in noise i've already described in another recent thread. as i work my way thru my music collection i continue to be reminded of the effect of less grunge.
i live out in the boonies so my environment is likely not as noise polluted as some others; but i know there is plenty of grunge to avoid.
sometimes grunge is reduced just by cleaning the contacts of your power cords or interconnects.
MylesBAstor
81
1,725
New York City
great subject.
The last line is the best!
I totally agree. Another really cheap tweak is to clean the AC cord plugs with something like Flitz or Gorham paste silver polish and then with Kontak. Sometimes it's amazing how much of a difference a clean contact can make!
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
"Grunge"? I thought this was about the Seattle sound or the Godfather of "Grunge"...Neil Young. My mistake...oops!:p
John
Doc B.
32
Yeah, being from Seattle I too thought maybe Charlie as talking about the Kurt Cobain exhibition at the SAM. I may have been the one to mention a studio that built the tracking room as a Farady cage. Different Fur (then Different Fur Trading Company) in the Mission in San Francisco was still under construction when I was a teenager taking a class on the operation of the Moog MKIII, and at the time the walls were being lined with sheets of copper. Pretty expensive solution.
I will encourage everyone to try to learn about this stuff on a component level. There are definitely certain bits inside the box that are more susceptible and concentrating on protecting those parts can be a pretty effective way to reduce noise. Regarding testing stuff like the military does - I was given a tour of a facility that does analysis of EMP effects on military gear. The source of the interference was a piece of foil 1cm square, which was instantly and completely vaporized by a bank of capaitors each the size of a refrigerator. The resulting pulse was piped thru waveguides to a room lined with RFI absorptive material, where a Cruise missle was hanging. Thankfully we probably don't need quite the level of testing that the military pays for to make sure our gear is resistant to EMI.
Of course the electrostatic stuff is only part of the problem, there's also magnetic fields that can inject 60hz in all sorts of sneaky places, causing a subtle but often infuriating softening and blurring of bass. A neat tool that PJ came up with is to simply take a 1mH RF choke and clip it across a pair of test leads attached to a scope. This make a great tool for snffing out magnetic fields and judging the relative intensity around the source. This is how we determine the placement of the transformers on our chassis to minimize coupling between the various inductors. Unfortunately the really really nice sounding step up transformers we have been working to get on the market work the same way, even with two layers of mu metal and a layer of copper on them.
We just set up our system in our new office. The setup is so new that I haven't had a chance to look at the AC mains with a scope yet, but we do seem to have our own power transformer and so far the power seems to be clean enough that I am getting a little better resolution than in my old room. However if you are considering a big honkin' transformer dedicated to your system think about placement. Ours is in a chase on the other side of the stairway up to the listening room, and it is quite noisy. We will have to add some mass to the wall that it sits behind.
Mark (Basspig) Weiss
682
38
940
New Milford, CT
www.basspig.com
I've decided to weigh in on this, only because of the fact that I actually worked as Chief Engineer for numerous AM & FM radio stations in the Northeast over the years, as well as because I have RF design experience and was in the process of producing my own line of broadcast equipment. So here's some of what I know that applies here:
RF pollution comes in many forms. The nastiest is UHF TV, because of the super power levels (up to five megawatts) and short wavelengths' ability to get into smaller spaces within equipment, vent holes, etc. as well as the fact that it carries both audio and a rather complex and (audibly) nasty visual amplitude modulated carrier at the higher power level.
A simple RF carrier gets into power supplies and becomes audible in the linear power supply when the rectifiers are just coming into or going out of their conduction cycle at points just before and after 90° and 270° on the AC power waveform. When RF is riding on this current pulse, the eddy currents become able to travel throughout the chassis/PCB traces far more easily, since the RF acts like a carrier, only the audio this time is the 120 cycle switching of the fullwave rectifier. This manifests itself as a 120 cycle hum in the audio system. I see this a lot in radio studios that are co-located with the transmitter.
Modulation on RF carriers just changes the intensity and type of noise we hear. It can be the 60 buzz of the vertical interval blanking signal on a television carrier, or audio program material on an AM or FM station.
Mitigation of these types of pollution involves:
Stopping it from getting into the power supply
Stopping it from getting into the chassis and interconnects through free air
One of the cheap and dirty tricks I use to mitigate neighbors' complaints when a station receives a telephoned or written complaint from a nearby resident, is coiling the AC line cord nearest the entry to the equipent into 4-5 turns about 3" diameter as a coil, and ty-wrapping it to stay put. This forms a VHF trap and is the cheapest form of relief.
Sets with plastic cases can be mitigated with aluminum foil, though it is important to make certain no ventilation slots are blocked and that no electrical terminals will come into contact with the foil. Grounding the foil will sometimes help.
Ultimately, the better solution is to RF toughen the equipment. This involves modification to the power supply. I like to use ferrite transformers in series with the AC line, using the cross coupling to shunt the HF noise, while the windings in series pass the 60Hz unimpeded. This, followed by common mode and differential capacitor banks to shunt off more noise. On the rectifiers, I add snubber capacitors. In severe cases, I even add inductors/chokes in series with the rectifiers, forming a choke input filter. Finally, relocating the ground return from the transformer as far as possible from the load ground within the unit results in reduction of rectifier switching eddy currents. The common mode stuff is the hardest to remedy.
The next thing to deal with is the inputs. In severe RF environments, I put 47uH chokes in series with all inputs and outputs, with 47pF shunt capacitors after the chokes on the amplifier circuit side. This attenuates the RF coming into the equipment through audio interconnects.
The use of quality, shielded cables for interconnects will be most noticed in an RF polluted environment. Many cheaper cables have spaces between the braid weave. Better cables like the Monoprice stuff I use, have denser braids that leave little open space for noise to leak through. This will benefit both the RF shielding and increase immunity to 60Hz hum from nearby line cords and other sources of EMI.
Lastly, orientation of equipment can make a difference. Broadcast RF is a coherent wave. As such, it behaves like standing waves in a room, due to multipath (reflections and bouncing) of RF energy from an FM or TV signal. Thus, moving a piece of gear 6' (about half a wavelength for an FM broadcast) can make a big change in interference.
I have a lot of experience with this as I live in the center of the aperture of a 50,000-watt FM/AM combo station, and cellular site. They have two bays of ERI rototiller at 499' HAG, and the field intensity at my property is enough to lock up digital personal electronics like PDAs and video cameras. To mitigate this, I shielded the house during construction, and grounded the shields to earth every 6' through straps at the foundation. The house is a Faraday cage, essentially. I have zero RF pollution in the house.. of course no cell service either, which is a slight inconvenience.. but my audio gear is clean and free of 'grunge' from electrical noise, having taken these measures over the past 38 years.
MylesBAstor
81
1,725
New York City
And I'll weigh in and say that in a system that doesn't suffer from RFI, chokes and coiling wires degrades the sound. Been there, done that. If it was that easy, everyone would do it.
FrantzM
29
405
And why would that be? What about the very huge inductance to which YOUR power lineis connected, the power transformer outside your house? Have you performed a controlled in which it was clear and conclusive that it was so ?
You clean up tour AC your system will sound better.. Of course there are ways to do so.. Just dropping ANY isolation transistor in a system is not a guarantee of great results.. properly sized and designed they enhance performance. That is all there is to it ...
MylesBAstor
81
1,725
New York City
Of course. Knew what it sounded like before, listened to it with the chokes and other RFI remedies like Ferrite beads, cord looping, etc in place and then took it out. The cure was worse than the disease. Luckily this guy only seemed to broadcast on Sunday afternoons; of course, that's when we used to have our listening sessions :(
