Headphone help for a simple man
marktheman
1
61
I have an audio technica lp120 usb turntable which is wired to a set of edifier r1700bt speakers.
I want to be able to use headphones both bluetooth ones for when I am moving around and wired for when I want to chill and listen to analogue music and preferably I want to keep the speakers connected rather than having to pull leads out every time I want to change.
I know I need a headphone amp but I need help to find one that will match with the above criteria.
The audio technica has a line / phono switch and built in pre amp as well as the red and white phono outputs and also a USB output.
Thank you for your help.
Mark
Gregadd
1,787
1,850
Metro DC
There are receivers like Marantz that support bluetooth. Moreover my Sony WH 1000xm4 do not require outboard amplification.
See thread on this site.
Reactions: marktheman
