I am looking to purchase a new receiver. I am not experienced with ohms and watts etc and pairing them properly to find the best match. I want to pick the best amp for my home theater. I have 2 JBL floor speakers that I’ve had for 20 years. I powered them with a 1982 Technics sa-212 receiver which finally broke. My speakers information is found here
www.nodevice.com/service-manuals/home-audio/jbl/lc-310-1/271806
I was looking at Best Buy and want to purchase a newer model amp with Bluetooth technology and also the ability to add a couple small speakers if I want to add surround sound down the road. My 2 JBL’s have highs mids and lows. The sub is a 10”.
Here are two receivers I was looking at
Sony:
www.bestbuy.com/site/sony-725w-5-2-ch-hi-res-4k-ultra-hd-a-v-home-theater-receiver-black/6187502.p?skuId=6187502
Yamaha:
www.bestbuy.com/site/yamaha-5-1-ch-4k-ultra-hd-a-v-home-theater-receiver-black/6198554.p?skuId=6198554
will these receivers work for my speakers? Do you have a better recommendation if these won’t pair well? I also have the old speaker wire with no RCA ends. Will this be a problem?
I want the best sound to pair with my JBL’s??
I appreciate any help! Do these new receivers not evenly put out the same watts per channel? Are they designed for specific speakers for each channel?
Thank you,
Rylan
Sony:
Yamaha:
Thank you,
Rylan
