hORNS Universum 3 MKII
Argonaut
2,415
1,646
530
N/A
I would be interested in any first hand considerations of this particular 3 way horn.
[video]https://m.youtube.com/watch?v=3i-Mle5CWRg[/video]
Billy Shears
255
1
150
Hi Harlequin
I cant offer first hand experience but there was a very detailed review in the german stereoplay magazine which i found very interesting: This Design is differnet from other Horn loaded Speakers,
- The Midrange driver is a Berillium dome with pressure chamber and is limited to max 3 octaves (so no broadband here) which minimises coloration according to hORNS.
-The Bass has its own A/B Amp... detachable (so its semiactive quasi bi-amped)
-The speaker is 95.6 Db Sensitive.
Sound? Apparently it had much less coloration and better imaging than most other horn speakers they heard.
Billy Shears
255
1
150
The finish on these Horns are the Ultimate Rohrschachtest..
Maybe Oneobgyn can tell me if its just my mind or not :)
bonzo75
22,620
13,639
2,710
London
I will be listening to them soon. The UK distri of Lampi has these, you can check them out, he lives a bit further up from Lewes/Tunbridge Wells
Argonaut
2,415
1,646
530
N/A
They are certainly worthy of consideration bonzo, considering the footprint and relatively 'real world' RRP.
The ergonomics of form are much more appealing to the eye than 'a couple of planks and a baffle with DIY Esk Ply horns stuck there on!
JackD201
1,427
1,820
Manila, Philippines
These look like a job for Onehematologist. They sure look like red blood cells :)
audioblazer
766
208
1,605
Malaysia
I the that video is taken in Munich show . Heard it in Munich & quite like it esp this year . Beautiful looking horns & can be painted to your specification. Know of a dealer with all white pair & reasonably price .
Billy Shears
255
1
150
Bloodcells? oh dear then there is something wrong with my mind! :p
Elberoth
2,011
259
1,170
Poland
I believe those are not painted by injection moulded (in a specific color) - like the Avantgardes.
spiritofmusic
14,625
5,432
1,278
E. England
I'm struggling to work out the horns topology.
AG Duos have tweeter and mids horns, w/pwrd woofers subs.
AG Trios have upper mids and lower mids horns in addition to tweeter and pwrd subs.
Tune Audio Animas have tweeter and mids horns, w/downfiring woofer horns, and separate pwrd subs if wanted.
Where do these horns fit into all of this?
Billy Shears
255
1
150
Downfire active woofer below 350hz Midrange compressiondriver 350-3khz Tweeter above that
Hi Harlequin
Blue58
898
685
1,155
London, UK
With 95.6dB sensitivity it looks like the horns are doing very little.
Billy Shears
255
1
150
spiritofmusic
14,625
5,432
1,278
E. England
I thought a big plus point of horns was to max out on sensitivity ie 105dB at least. Doesn't look like that's the case here.
Duke LeJeune
Jul 22, 2013
747
1,200
435
Princeton, Texas
They're providing radiation pattern control, which imo is of far greater benefit than acoustic amplification.
Note that you need a really quiet system for it not to have an audible noise floor through 105 dB speakers.
DaveC
3,899
2,142
495
I agree, but also wonder what drivers they could be using and how the sensitivity could possibly turn out so low...
Billy Shears
255
1
150
Sorry to keep having to repost my own quotes but they seem to be hard to read :)
The midrange is a 50mm and the tweeter a smaller version of the same driver, both are custom made for hORNS.
Again i think the lower senisitivity is a good thing as Fidelity and ultra high senisitivity dont necessarily go hand in hand.
Billy Shears
255
1
150
zztop7
750
3
Edmonds, WA
Beryllium dome surface area & sensitivity
The midrange is a 5mm and the tweeter a smaller version of the same driver, both are custom made for hORNS.
5 millimeters does not look correct / 5 millimeters is one fifth of an inch - the tip of a baby's finger.
I have two pairs of beryllium domes from different manufacturers - actual 4 inch diameter domes = 100 millimeters / 5 inch total outside diameter = 125 millimeters.
Surface area to produce sound; the 4 inch dome [100mm] would have 400 times the surface area of the 5mm dome.
105 Db sensitivity is easily exceeded with a proper beryllium dome. The problem is that the beryllium dome walks all over the other drivers. Therefore, the signal to the beryllium driver must be attenuated to properly match the less sensitive drivers. That is probably where the 95.6 Db happens.
Respectfully,
zz.
