How to be an audiophile on the cheap
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
"You will need a good album to test your setup. How do you pick which recording to start with? Michael Fremer weighs in:
A good recording of acoustic music is the best way to judge a system's quality, especially if you attend live music performances. That way, you have a known reference. But ultimately it all depends upon your musical tastes. If you like rock mostly, you can't go wrong using "Nirvana Unplugged" or "Alice in Chains Unplugged." Both are superbly recorded and feature both acoustic and electric instruments. I promise you the double vinyl issue of Alice in Chains sounds so much better than the CD version, it's ridiculous!
True?
Gregadd
1,790
1,850
Metro DC
AMIR quotes Fremer ??????
:confused:
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
True?
In principle and only if you can tolerate the music.
Billy Shears
255
1
150
True?
Yes, but listen to what ever you would listen to the most. If you only listen to electronic music i dont see why you need to demo with anything else.
bonzo75
22,643
13,674
2,710
London
With acoustic music there is more of a right and wrong to tone than with miked music. Also orchestral pieces have 50 instruments, so multiple frequencies going to the same driver, across drivers, and with varying voltages and large voltage jumps. Much more challenging than reproducing 4 instruments
GaryProtein
2,542
31
385
NY
The same goes demos using an instrumental duo or trio playing with a single female vocalist--what a waste of listening time.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
True?
Yes! I'm traditionally not a big fan of either band, but the Unplugged albums are truly outstanding.
bonzo75
22,643
13,674
2,710
London
You can say that about a lot of things Mike listens to, not to mention the volume :D!
Who Mike, lavigne? What is the reference to volume?
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
No! Fremer.
david
I don't listen to that same loud angry music that Mikey does.:eek:
OTOH I like Nirvana Unplugged just fine.
I'm a 65db-80db listening level person depending on the mood, more toward the lower part. mostly acoustic since it's mostly classical and jazz.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Good to know as I had already ordered the two CDs referenced when I read the article :). I listened to the Youtube versions and they sounded a lot more mellow than I expected. What got me over the hurdle was that both CDs were priced around $5 on Amazon!
BTW, whatever happened to unplugged series? Did it get unplugged the same time MTV went after Rap and youth programming???
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
I am way tilted to the higher side for music that demands it. :) I like to feel the bass and that doesn't happen for me at low volumes. Most of my listening is Jazz these days and it too demands high volumes for that effect.
Of course it all could be justification for growing deaf in my older age. :)
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
I recommend the 'Best of Unplugged' CD's as very very good acoustic pop music. there are some true gems on those CD's.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
??? Last time I was listening to Nina Simone. Much of her material is simple like that, with Piano, some of kind of drums softly playing and her voice. Was I wrong to admire that music?
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
my perspective on volume and bass involvement is that I'm much into a system that gets the bass nuance at modest volumes. and system noise floor and the first watt magic are pieces of that puzzle. and lots of what I listen to has quite wide swings in volume levels. it might be mostly low 70db range but peaks get up there quite high.
OTOH with visitors I typically turn it up and the bass gets more physical. but a 2 hour session has a different vibe than a 6 hour one. 6 hours at 80db+ as an average gets assaultive. I listen easily 30+ hours a week, and that's attentive listening.
even in the 60's and 70's (my teens and 20's) I avoided high db listening as a rule......unless properly medicated. which for me was seldom.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Thanks Mike. I had a couple of them already:
Any others that come to mind that you would recommend?
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Then we are doing the same thing. I turn up the volume for a few minutes at a time and then dial it down based on mood and what I am listening to for the rest of the period. Yesterday for example I must have listed to my system for 6 to 8 hours with no fatigue whatsoever. Weekly I am easily where you are at with respect to hours.
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
