I said I would never buy another Turntable...Argh !!!
rockitman
7,097
414
1,210
Northern NY
Christian,
i'm skeptical that your wood floor can handle the pounds per square inch of the feet of the Nothing Rack + AS-2000 without some unpredictable deflection. whether it's deformation of the wood, or the support beneath, i'd recommend some consideration before it's all in place. if those wood slats are directly over concrete maybe you are ok. but maybe not. if it's directly over concrete i would think about cutting out the wood in that area to get directly onto the hard surface.
once it's in place and deflects (each footer will not deflect equally) it will be hard to fix it.
I already had a re-inforcement beam installed with a 30,000lb load capacity. There will be no floor bowing or deformation. It runs right underneath the equipment area/right speaker. The flooring is 1” oak on top of 1” plywood (radiant heated floor) which sits on the floor joists. Perhaps a floor plate will be in order. I can always take the top plate from my herzan AVI table unit and put the AS/AS Stand on top of that. The steel plate would disperse the feet loads more evenly.
Thanks for bringing it to my attention...
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
1" Oak over your added beam will likely be sufficient i would think. the Nothing Rack feet are wide enough with wood that dense there will be no deformation of the wood unless it's flexing below, and the beam should handle that. if you add the other plate then the floor and plate can have their own issues.....still dependent on the under support.
i think you have a good plan, sorry to throw that out there without reading the rest of the thread.
room looks fantastic by the way.
Reactions: rockitman
16,215
13,690
2,665
Ha Christian, you beat my main (non audio) ceiling ht by 4' (we're *only* 20' high).
Room dimension calculators never reflect this but, subjectively, I think high ceilings are good for audio systems.
16,215
13,690
2,665
David has estimated around 700-800 lbs. I wish things were lighter in the TT world....lol
I truly do not understand how David gets this stuff packed and transported around the world.
4,702
Vinyl now spinning. Second shot is the 24’ ceilings. Headroom used to be 8 ‘. Music fully blooms now before hitting the ceiling barrier. Taped area for AS2000. View attachment 47558
24´ ceilings? You really deserve a a pair of WAMM's - and although you will have to hide them from David, a pair of Master Subsonic subwoofers!
Tango
4,938
6,269
950
Bangkok
16,215
13,690
2,665
Futures are pricing in a 65% probability that Christian will have Master Chronosonic speakers in there someday.
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
considering the ddk influence, the odds are higher going to horns, which would also play more to that room than dynamic cones. the only drawback is that big horns would block the view. but less so than lowered window coverings.
Reactions: bonzo75 and ddk
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
That light fixture is gorgeous indeed but I wouldn't want to be the guy to get up there to replace a burned out bulb ;)
+1 on the classy fixture.
my ceilings in my family room and living room are 26' tall; i have an extension pole with a suction tip that works fine. dropped one bulb in 14 years and it did not break even.
rockitman
7,097
414
1,210
Northern NY
I re-checked the floor. 3/4” Red Oak Floor planks over a sandwich of two 3/4” OSB plywood on top of floor joists. CCFF341C-9DD6-4D75-883A-C7F2042EE53A.jpeg
Reactions: Mike Lavigne
I understand and have seen those extension poles which work best if the bulbs are below rather than above the fixture which these are . I can't see that working for Christian
I think Mike does have a point Christian
If you have the original plans it would tell you what weight the subfloor is built to tolerate
In my neck of the wood the standard for residential floor is 40-50 lbs/sq foot and about 80 lbs/sq foot for industrial.
Like Christian I have very heavy equipment and we have the same speakers. When I built my room on the second floor over my living I wanted to take no chances that there would never be a problem and my sub floor was designed to support 1500 lbs/sq foot
A mechanical engineer can easily give you good advice if you need additional support in the room t
rockitman
7,097
414
1,210
Northern NY
The support is there....My General Contractor looked into it.
