Gregadd
1,787
1,850
Metro DC
I am not sure what firmware is. I am using an android fed by Xfinity wireless router. If you need more info?
Gregadd
1,787
1,850
Metro DC
I use a samsung s 9 plus.
Gregadd
1,787
1,850
Metro DC
i received an update from iFi Audio. They were unable to replicate the situation of which I complained. Nor hass review revealed a similar problem. I assure you that it was real. Perhaps it was intermittent and unique to my unit.
Edit
The main board was replaced out of caution
Gregadd
1,787
1,850
Metro DC
The problem seems to be cprrected.
Gregadd
1,787
1,850
Metro DC
I think I found a new use for the Diablo. I'll report back before Christmas. It should apply to hip dac dac and Go blue.
Gregadd
1,787
1,850
Metro DC
I need a converter for the Diablo. But the hip dac worked fine on my car stereo.
I think the Diablo will be a better fit.
Gregadd
1,787
1,850
Metro DC
Vablee arrived 3.5mm to 1/4". From Amazon
Gregadd
1,787
1,850
Metro DC
You guys are so smart I don't always explain things fully.
As most are no doubt aware some car stereos have an aux function. This allows you to plug your smartphone into your car stereo. You then use it as a source. What I propose is to place the Diablo in between the smartphone.
Wearing headphones while driving is not only dangerous but illegal in some states
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
I am happy to hear you found another way to make most of your Diablo. 3.5mm to 6.5mm is a useful converter. I believe you should have a 6.3mm to 3.5mm included in the Diablo set, so in case you wanted to use a 3.5mm to 3.5mm cable you would not have to purchase a separate cable.
Gregadd
1,787
1,850
Metro DC
Yes I found the converter. Not everyone manufactures hardware to your exacting standards.
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
Of course. However, if you look at it from a different perspective, the art of composing a complete audio set-up, if it was not not a challenge, would it be that much fun?
Gregadd
1,787
1,850
Metro DC
This is the lake I sit by when I take the Diablo out for a walk. OK it's a catch basin. You get the point.
Reactions: Audire
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
iFi audio Question: What $1k DAC gets used at a show with a $300,000 system and gets one of the 'best sounds of the show by Stereophile?' Diablo of course!
https://www.stereophile.com/content...fh5umdFGhb7skkW1N8BBQ5064K7r0&mibextid=Zxz2cZ
“And what about the iFi Diablo? What's a C$1300 DAC doing in a system with a C$350,000 amplification chain? Is Mr. Lemay of Lemay Audio crazy for including it? Crazy like a fox. I said it in last year's report, and I'll say it again: The iFi Diablo is a giant killer.”
Even Michael Fremer... “that was so funny.... the DAC they switched in was an iFI DAC and they said sounded better than ANYTHING else they used in the room. I was shocked!” On the big PMC speakers and the Accuphase amps.
Gregadd
1,787
1,850
Metro DC
...$1.3k?
It is a dac and an amp.
