The thought crossed my mind on whether I can get close to a high end source by putting in a dedicated clock in front of a high end dac. Enter the Empirical Audio Synchromesh.
Just had my Empirical Audio Syncromesh modded by Steve Nugent to his new 7 psec configuration and the result is nothing short of stunning. I had his previous upgrade done a while ago and that was a step up from an already seriously high level of performance.
The lift in cohesion in resolution combined with organic 3D is outstanding as are decay trails and harmonics. No edge but an increase in detail - which is very hard to get. Best described as a high quality turntable.
In my rig, the Syncromesh is fed by Argento reference digital cabling and the output is a Shunyata SIGMA BNC. The cost of the cables are multiples of the Synchromesh price. The DAC is a Metrum Adagio NOS which is very detailed especially when run direct to power amps. So it is a real test for the quality of ancillaries.
The Syncromesh makes my system shine and I recommend very highly. Never underestimate the power of the clock in a system. At 7 psec - that’s extraordinary.
Also recommend a high quality linear power supply. I use an Sbooster with Shunyata Alpha PC but I suspect the Paul Hynes LPS Empirical Audio is a killer combination.
Moral of the story is that despite a very high end dac, an excellent clock interfacing with it makes a serious difference.
