Interconnects - Ansuz?
Griff500
22
16
3
55
I thought I'd post this in it's own thread.
I'm looking into whether upgrading interconnects could improve what is already a fantastic sounding system. I am currently using Belden 8760 XLR interconnects from my DAVE to my active speakers (ATC SCM40A) but I am curious about what difference, if any, other interconnects might make. I think the cables I have are excellent for the money, which was next to nothing.
I'm using Ansuz distribution and power cables (C2) and I'm tempted to try the Ansuz XLR interconnects. A2 and C2 are available at a price I'm comfortable with. Has anyone tried these? Alternative suggestions? Or perhaps what I have is not going to be bettered and money would be better spent elsewhere.
3125simon
90
99
83
59
Uk
I had C2 in my system - both XLR Zane RCA. Replaced Furutech Flex and Cardas Clear Beyond. In my system this was a big improvement, not as big as the power cables, but very positive - more detail, bass and extended highs. Not bright or fatiguing with my then Vitus, Sonas Faber System that needed opening out as a little too dark and rich.
so like all cables, a little system dependent.
if you are in the UK, Lotus Hifi has a used 2 m XLR c2 in his pre-owned.
good luck with your changes
Griff500
22
16
3
55
Thanks.
I can also get A2 for about £1K less but I'm inclined to stick with C2.
At this stage it's a question of adding more power cables or interconnects first. I'll soon have 3 power cables and I'm leaning toward using them the amps in the active speakers and to the distributor, although I could use the 2 amp cables for components instead. I'm guessing I should upgrade power cables for amps ahead of components.
What did you replace your C2 interconnects with?
3125simon
90
99
83
59
Uk
Thanks.
C2 is much better than A2.
I only changed my Ansuz interconnects as I made a big upgrade of my system with Tidal:- Piano G2, Prisma, Impulse and changed my interconnects to Tara Labs Muse.
I could easily have stayed with the Ansuz.
good luck
Reactions: Griff500
Griff500
22
16
3
55
good luck
Maybe I'll give them a go.
I also saw a DTC power cable but it looks too cheap at 3,200 EUR.
3125simon
90
99
83
59
Uk
I saw that also.
Looks cheap, but the model has been superseded.
Huge depreciation....but the DTC would make a huge improvement between the wall and the Mainz8.
Griff500
22
16
3
55
Monumental depreciation. I wonder if it's still 'better' than a C2 as a primary cable into the distributor.
I'm thinking power cables ahead of interconnects but I am tempted to try the C2 XLR cables.
LenWhite
424
72
375
Florida
systems.audiogon.com
I have an Ansuz C2 PC from the wall outlet to the Mainz8 with A2 PCs from the Mainz8 to the EMM Labs DV2 and JL Audio CR1. I have a C2 XLR from my DV2 to the CR1 that was clearly an improvement. But the power system (Mainz8 and PCs) made the biggest difference system wide.
Reactions: Griff500
felix01
10
2
108
hello,
i see you have some ansuz in your set up;i am quest new to ansuz and have allready some xlr cable and powercord C .Know i am thinking about a mainz 8 D with PC. I am wondering if it would be an improvement to the shunyata triton v1 what i have know?Any idea about it?
LenWhite
424
72
375
Florida
hello,
I've never heard the Shunyata Triton V1, but the Mainz8 DTC I installed made an obvious improvement in the sound. I had previously used the Nordost Quantum Qx4 which is not nearly as revealing as the Mainz8.
