Introductory range
Stacore
503
80
28
Gdańsk, Poland
stacore.pl
#1
Dear all,
We are working on a new, introductory range of products. We will be introducing simpler, lighter, and much more budget friendly solutions for less demanding applications. The plan is the following:
- Slate constrained layer damped (CLD) platform on massive, adjustable steel spikes; simple yet efficient solution in one or perhaps two variants
- Roller bearing + slate CLD platform; a step up from the above, employing our deep hardened steel bearings for LF isolation
- Steel/slate CLD footers; a massive design, combing special formulation stainless steel and slate for improved damping
Both the CLD and the Roller platforms can be incorporated at any moment into our racks as shelves. This gives a user a fantastic flexibility: One can start from simpler products and move towards the pinnacle of our design - the rack system, incorporating all into one, coherent solution.
Cheers,
PeterA
5,486
376
83
North Shore of Boston
#2
Congratulations, Jarek. I wish you success with these new products.
Have you given any thought to footers designed for speakers? I have heard the effects of Magico MPods under a pair of M Pro speakers, and they seemed very effective at reducing vibrational energy entering the floor from the speaker cabinet. My speakers are on a suspended wooden floor, and, if I ever get around to it, experimenting with some CLD footers with compressed layer of IsoDamp to see how it changes the sound.
Stacore
503
80
28
Gdańsk, Poland
stacore.pl
#3
Thank you very much Peter!
If circumstances permit, our platforms work just great under speakers. However, some speakers are simply too big or too sensitive to rising the tweeter, so yes, a dedicated speaker solution is on our mind for sure.
Cheers,
Likes: flyer
dcc
270
90
28
Continental Europe
#4
Hi Jarek,
I wish you all the best with this new range of products. For sure, your new footers are a very interesting design and I am looking forward to testing them with you superb and highly effective audio rack.
Kind regards,
Denis
Stacore
503
80
28
Gdańsk, Poland
stacore.pl
#7
A new model -- STACORE INTRO -- officially released!
An introductory platform for less demanding applications. A rigid design, based on our CLD damped slate, supported on beautifully machined 3 or 4 spikes, exchangeable with our CLD footers. Lightweight for Stacore standards
;) but still quite massive at 35kg to take an advantage of the mass damping. Can be integrated into our Rack System as a rigid CLD shelf. Max load 60kg [3spikes], 120kg [4spikes]
http://stacore.pl/en/
Flyer already testing it in his fantastic system :)
Cheers,
