KLAudio is back with a new RCM: the KD-CLN-LP200T. Looks like it continues to be made in Korea.
$6000 available at Acoustic Sounds who is the distributor. Sounds like AS had a hand in returning KL to the marketplace.
There is also the KLA LP Loader which works with the LP200T. This lets you process 5 records in succession. $3080
A noise isolation box will be available similar to the original. Reminds me of dot-matrix printers.
-- The new LP200T looks physically robust. Something is made of it having "200W total ultrasonic cleaning power". Not sure how this translates in effectiveness for this particular machine because tank volume is not specified. (The Elmasonic P120H tank operates at 330W (~100W/gallon) with peak power of 1320W.)
-- KL/AS does not say transducer frequency. Iirc the orginal operated at 40Hz. If this new model had dual frequency you bet it would be advertised.
-- A cooling unit (fan) is an option to maintain water temperature. Cooling unit kicks in when water temp reaches 35°C. A nice feature.
-- Includes an external water pump and filter. We are not given any information about the filter.
-- Wash and dry cycles independently adjustable 0-5 minutes.
-- Water supply available via an external tank with a filter. This looks like a plus for easier tank changing.
This new model retains what imo is the original's basic weakness - it does not allow the use of anything beside water.. Ultrasonic action alone is effective, but to get a record really clean some chemistry is needed to lower surface tension and gain some detergency - or so says my years of experience with a variety of record cleaning methods.
I was surprised the manufacturer states:
Fill the reservoir with tap or bottled drinking
water to about 75-90%.
Distilled water is not recommended, because
the electrical conductivity may be too low for the
cleaner to begin the wash cycle.
The original KLAudio machine had many fans. I suspect this new machine will be successful although it now has more marketplace competition than previously. Welcome back KLAudio.
Unboxing video:
Record Cleaning Machine|Acoustic Sounds
Acoustic Sounds Audiophile Vinyl Records
store.acousticsounds.com
Klaudio-Automatic Disc Loader-Record Cleaning Machine|Acoustic Sounds
Unboxing video:
