I know there are several of you on this forum who at one time had both of these preamps in your system. The KRC-HR is the newer and much more expensive of the two and it does have a cool remote. I was told to expect a bigger, deeper soundstage with a better top-end with the KRC-HR in comparison to the KBL. The first 24 hours the KRC-HR was in my system it left me cold. After 24 hours of being on continuously it came to life and sounded much better. As time went by I started having some nagging doubts about the KRC-HR's sound quality compared to what I was used to hearing with the KBL.
The KBL is a very ballsy preamp. For some reason it just oozes power and you almost feel like if it had some speaker binding posts it could drive your speakers. Looking at the specs of the KBL and the KRC-HR, the line stage gain is the same. They both have a gain switch where you can switch in an additional 6dB of gain and that is available via the remote for the KRC-HR. For whatever reason, the KBL just sounds far more powerful than the KRC-HR. When I listen to digital files through the KBL, I have to take out the additional 6dB of gain in the line stage because as soon as you turn the volume knob past the "off" position it will blow you out of my room. This doesn't happen with the KRC-HR. I can leave in the additional 6dB of gain for all of my sources when listening to the KRC-HR.
Never mind the volume issues though, I'm becoming convinced that the KBL is the better sounding preamp. The KRC-HR sounds maybe more polite and refined, but I'm not convinced that it represents musical reality in that many instruments aren't polite sounding when heard live. Stand close to a live band that has any brass instruments and you will understand what I'm saying. The KBL sounds more like a good tube preamp minus the noise inherent in vacuum tubes while the KRC-HR reminds me more of SS. There might be more edge definition with the KRC-HR, but it comes at the expense of the whole note and the images they create if that makes any sense.
I would like to hear from people who owned both of these preamps and see if you can recollect whether or not when you bought the KRC-HR if you thought it was a much better preamp and if so, why? Did you ever have any nagging doubts that maybe just maybe the KBL might be better? I know I am and I currently have both preamps. I need to put the KRC-HR back into my system again, but I'm having a hard time forcing myself to do that.
