MA-1 Lumen Reduction for the Red/Yellow Lamps
Mrmb
29
20
310
Can anyone recommend a way to reduce the light output of my MA-1 Mk.3.3 factory installed Yellow and Red Lamps? I assume they could be replaced with lesser output lamps. But which ones would work/ be recommended?
bonzo75
22,621
13,641
2,710
London
Ralph might know
Mrmb
29
20
310
Thanks Bonzo75, this is obviously a pretty basic aesthetics question vs a more important functional one. As such, it's NOT overly important that I get a quick response. Hence, I thought if others had used a different bulb or done something to ameliorate their light output, they may reply here -- and of course, if Ralph saw this, he may reply -- and by doing so may help others.
I must add that I have had many direct communications with Ralph Karsten before and after my MA-1 purchase and have found him to be most receptive and rapidly responsive. Ralph is indeed generous with his time and knowledge both directly and on forums such as this. My difficult-to-drive with aplomb Soundlab M1PX speakers, simply thrive on Ralph's (Atma-sphere) OTL power!
BTW Bonzo, I've enjoyed your posts. Until recently, we both owned Golden Gates and your posts about Lampizator in general and the GG specifically were appreciated.
jeffreybehr
187
142
130
80
Phoenix, Arizona USA
www.flickr.com
MrmB--I've had M-60s and have MA-1s.. I just remove the bulbs.. Ralph has told me that they drive the bulbs with as little Voltage as it takes to get them to start glowing, and there are no lower-power bulbs.. If I come up with something, I'll let you know.
Mrmb
29
20
310
Yup JeffreyBehr, removing the bulbs, or (as I thought before asking the question) covering them with something to reduce their output, would both be methods to do what I'm asking. However, I was hoping for a more elegant fix (light reduction method).
1kitch
10
I use 3894 Miniature Lamps as a replacement for the stock lamps to reduce the light output.
ferrox
262
55
158
Jakarta, Indonesia
www.primes.asia
Two weeks ago I have my MA-1 checked by a reliable local tech. The issue were: 1. R channel red light is dimmer than the L. 2. R channel hummed and I had to tap the 1st and 2nd driver tubes to silence it. I consulted with Ralph and he is again, correct. The tube socket were too loose. As for the dimmer red light, just clean the bottom of the bulb. Now both channels have similar light ray. :p
