need a abomorphic lens for benq 2150st projector
markyboy156
8
52
hi
i need a anomorphic lens that does 2.35.1 using a benq 2150st projector that is 9 feet away and is ceilung mounted im using a large painted wall using shermin williams proclassic satin extra white with grey colour dye in it
i no the benq 2150st does not support 2.35.1 built in which i why im enquiring about a anomorphic lens to do this i dont i want to pay no more than £500-1000 on tbe lens thanks
MTB Vince
187
221
128
59
Dundas, ON Canada
The sort of questions you are asking on entry level HT products would be much better answered over on the AVS Forums.
https://www.avsforum.com/forum/index.php
This site tends toward the very high-end and mostly two channel audio. The Audio Video Science forums cover beginner to advanced home theater as their primary focus.
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
You meant "anamorphic".
* I think this site is more than two-channel stereo analog ultra hi-end with tubes.
It's also about what's best in everything else...the music, the movies, life ...
_____
? https://hometheaterhifi.com/reviews/video-display/projectors/benq-ht2150st-dlp-projector-review/
If you can find a used (or new) Oppo 203 Universal 4K Blu-ray player for less than $1,000 USD, it has a 21:9 moveable aspect ratio zoom, specially for front projector owners.
It's the simplest, easiest way to get what you want.
Before they stopped making them (April 2018) the Oppo 203 was retailing for $549 (USD).
https://www.avsforum.com/forum/68-d...968208-cheapest-4k-projector-2-35-1-lens.html
