Hi all,
I’m currently using a Silent Angel M1T Streamer with a Forrester F1 LPS via an N8 Network Switch. This is being fed by a British Telecom (BT) WiFi Mesh Disc that receives signals from my BT Hub in the next room which is about 20ft away. The WiFi Mesh Disc has an Ethernet socket on the back which I use to connect to my N8 Network Switch. Everything seems to be brilliant. As the connection to the Silent Angel N8 Network Switch is from the WiFi Disc the Chain is broken with regards to noise being transmitted along the Network cable. Am I correct in saying this? Everything sounds fantastic!
Thank you in advance to all who chime in with their comments.
