Sonic Artistry is the Best. The only place worth shopping for high end audio in the GTA.@JEB42 thanks for the info. Great lineup, the Toronto area surely benefits from such a great analog resource
Among several ridiculously false assertions in the latest OMA video, he mentions that "all vacuum hold down have a soft rubber material between the record and the platter". Is that true?Exactly. Can you see vacuum hold being applied anywhere?
most vacuum hold downs have a flexible rubber membrane integrated into the platter edge to hold the vacuum in. might also have a small rubber disc at the spindle to hold the vacuum. to say it's between the platter and the pressing is not wrong or right, it's touching the edge (and label) and each design would likely do it slightly differently. it's part of the platter<->pressing contact equation. the much larger issue is the possible 'over-damping' of the pressing by the vacuum effect. again, which will vary from design to design.Among several ridiculously false assertions in the latest OMA video, he mentions that "all vacuum hold down have a soft rubber material between the record and the platter". Is that true?
Speaking of the K5, according to the Tracking Angle review, it simply couldn’t deliver any high frequencies. Perhaps you can elaborate?
“Unfortunately, I could not appreciate its sound quality because the demo system had no top end at all.”
Munich High End 2023 Wrap Up and Alternative View
TrackingAngle hired a local to cover some of the showtrackingangle.com
