What do you guys think about Allnic H-7000V: http://allnicaudio.com/?page_id=1811?
So far, I've listened to Io Signature and Thoeress. Can't really decide between the two. Allnic is a new design, at least compare to Aesthetix. It is the upgrade to H-3000V, which was a well regarded phono stage. Has anyone compared H-3000V to Io or Thoeress?
Thanks.
I prefer the Allnic 5000, only marginally, to the IO eclipse. The 3000 is not as good as the 5000. Allnic reacts a lot to tube rolling. It's easier to manage than IO, only one valve to roll. I will be able to compare 7000 and thoress later in the year.
Ked - why 1 valve to roll on Allnic?
I think, they are both on the same level, equally dynamic, the Io is a little bit more dense and rich, Thoeress is more neutral. Depending on a cart and a system, you would choose one or the other. I could happily leave with both of them. Thoeress is very quiet and almost doesn't produce any heat.What differences did you find between the thoress and the IO signature?
You beat me to the punch Ked, i was sill writing when you respondedAesthetix will always be more dense, backward layered, and slammy. Big Midbass. It's usually the noisier one unless you roll tubes effectively to quieten it. Never compared 3000 directly to it but that is also tonally rich, nice wide stage, immersive. Aesthetix can get very macro dynamic. Different sounds. I compared Allnic 3000 to zesto and trulife with the stock recti and preferred the other two. I rolled the recti and preferred the Allnic. The zesto was cheaper, the trulife was much more expensive. Thoress and Allnic are both more flexible than the aesthetix. I listen to Allnic regularly in a system I like and it sounds great with the Soulution preamp.
Hi Kcin,Congratulations on the Eclipse.
It will startle you on those precious recordings. If you can live with the heat and real estate required it is still highly competitive. I have compared it extensively to Thoress and yes the Thoress is more flexible. Thoress has a FET input.
The Io can be more of everything it does well including quieter if you roll tubes.
At this level your personal preference is your guide. I have listened to the 1201, 1202 and 7000 Alinic and continue to keep the Eclipse with volume controls and two inputs. Their big 8000 model I have not heard.
Does the second phono input come with a second set of impedance switchesCongratulations on the Eclipse.
The only phono right now that I might trade for is the Tenor.
I still have not reconciled the CH in my mind , I have heard it on many occasisons I just struggle with the expense of the form factor all out. I spoke to Richard Mak about it at a gathering and he is very enthusiasitic about it when it goes to 4 chassis dual mono config.
You get a second set of loading inpedance switches. I have the 2 inputs with volume controls. I am not sure if they offer just two inputs with out volume controls.Does the second phono input come with a second set of impedance switches
or do you have to reset loading every time you switch inputs ?
Hi it is an impressive unit. It probably is quieter stock than the Io. It is expansive sounding holding a strong image specificity. I have heard this at my local Allnic dealer on a system that I have heard many many times over the years.Hi Kcin,
What is your impression about Io vs Allnic 7000? Have you had a chance to do a direct comparison?
Thanks.
Thank you for the information! The volume control is mandatory for secondYou get a second set of loading inpedance switches. I have the 2 inputs with volume controls. I am not sure if they offer just two inputs with out volume controls.
The Io can be made very quiet with tube rolling or by just keeping the stock tubes.
I believe the Io to be better front to back layering and tunefulness on bass believe it or not. Having said that I have not heard it on my own system so more listening required. There is limited to no tube rolling on these units which, I guess, may be a good thing for some.
Certainly the Io can be a tube rollers heaven or nightmare depending on your perspective.
For the money it is very well built.
