No USB on Zen Stream in Roon Exclusive mode
jmendes
6
1
3
62
Hi - I don't know if this is a Roon 2.0 thing, but my Zen Stream works just fine except for when using USB and switching to Roon exclusive mode, I don't get any output. In All In One mode, USB for Roon works just fine. When in AIO mode on the Zen Stream, in the Roon Audio settings, I see the Zen Stream and the associated USB interface (it's connect to a Signature One DAC). However, when I switch to Roon exclusive and I look at the Roon Audio settings it notes that the Zen Stream is using SPDIF (when I have the USB cable connected).
What's odd, if I am using USB I can go to Tidal exclusive mode, works great. I can go to DLNA mode and use Audirvana, works great. If I switch to coax, then I can use Roon in exclusive mode but not with USB.
This is very odd. Is there something I am missing?
Also - I could not find a way to start or move this topic into the Zen Stream thread…
~ Jim
christoph
4,674
4,071
825
Principality of Liechtenstein
~ Jim
Hello Jim
Welcome to the What's Best Forums.
Cheers,
Christoph
tom539
Active Member
Dec 28, 2021
50
165
40
50
@jmendes
open a web-browser and Open the Pi-Adress of the ZEN following by :3100 - example: 192.168.2.190:3100
There you can switch the output in Roon-Mode.
atb, Tom
Reactions: christoph
jmendes
6
1
3
62
Perfect! Work great. I will remember that port number. Not sure if iFi has those things listed, but I am thinking this is still a bug that will be fixed later.
Thanks again for the help.
Jim
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
@jmendes
atb, Tom
Thank you very much for your help!
Jim
I will send feedback to the lab. Please send me a DM with your Zen Stream's software version :)
