Oh-m'-god--bought a pair of MA-1/3.1s thru USAudiomart.
jeffreybehr
187
142
130
80
Phoenix, Arizona USA
www.flickr.com
Congratulations on these incremental improvements!
TY, Ron.
I ran into Upscale's Brimar CV1988/6SN7GT tubes and bought a quad; Upscale has sold out of the two better (preamp) grades and have only poweramp-grade versions left.. The first quad had blacked glass and original cartons/protectors and sounded quite good in the 1st-Voltage-gain postions--maybe not quite as warm as my old Tung-Sol oval-plates but excellent none the less.
Bought six more which turned out to be two different plate styles; none had blacked glass, two had common-type rectangular-cross-section black plates, and four had curved gray plates.. I left four T-S OPs in the V1 postions, put four original-black-plate versions in the Vs 2 and '3 positions, and put the rectangular-plate pair in the V4 cathode-follower postions.. THIS combination sounds EXCELLENT and made the amps sound better than ever.
I'm now working on amppads and shelves for my equipment stand, using 3cm granite.. IF anyone is curious, see
https://www.audioasylum.com/audio/tweaks/messages/20/208063.html
for details.. Got the amppads finished yesterday and applied some sheets of Dynamat damping material to both today.
https://www.audioasylum.com/audio/tweaks/messages/20/208116.html
Reactions: RogerD
chungjh
46
66
@jeffereybehr
I am thinking about MA-1 3.3 for soundlab speakers (may be 545), which is very similar in size to your Quad. How do you like them? Does MA-1 have enough headroom for your room? What is your room size?
jeffreybehr
187
142
130
80
www.flickr.com
@jeffreybehr
I LOVE the sounds coming thru these things; I think they're the best amps I've ever had.. One thing that convinced me to keep the MA-1s instead of the M-60/3.3s is their versatility; I'm now using them with only three pairs of output tubes in each amp to drive my 96dB-sensitive Serenity Super-7s.
I have a largish room (about 3200CF) and LOVE large-orchestra Classical and film music, but I don't listen at very high average levels. . The amps always had PLENTY of power for my needs, but I could only guess at whether they have enough power for you.
I'm using the Winged-C 6H13C output tubes instead of the Chinese version of the 6AS7G and a combination of Tung-Sol oval-plate 'N7s and BRIMAR CV1988s in mine; see pic above.
I wish you well; pls let us know what your results are.
Kcin
662
846
275
Canada
I bought a stash of the Brimar CV1988 tubes from my dealer friend 25 years ago - he was an Atma dealer.
The difference they made on the MA 1s was profound when he installed them in the showroom. Mine have sat in their boxes for years unused.. I have nothing that uses them now. They look cool. IMG_1347.jpg IMG_1338.jpg IMG_1337.jpg
jeffreybehr
187
142
130
80
www.flickr.com
Kcin
662
846
275
Canada
chungjh
46
66
@jeffreybehr
You had a picture of MA-1 driving Quad 2912 with subs. Did you replace your 2912 because of the lack of bass/slam, which is common in ESLs?
chungjh
46
66
Congrats on those amps which should sound exceptional driving the Quads! :) They do generate quite a bit of heat though... I have a buddy who used to own similar Atma-Sphere amps and he got used to listening in his underwear (and I'm not kidding!) :eek: All the best in the new year!
Can't you switch MA-1 to class AB from A to reduce the heat generation during summer?
jeffreybehr
187
142
130
80
www.flickr.com
@jeffreybehr
The Quads are 2905s.. I replaced the Quads with their predecessors, Serenity Super-7s, hybrid open-baffle planar magnetics with double-12" bass drivers...
https://www.audiocircle.com/index.php?topic=141060.0
...because the Quads' bass tended to drone a bit in my room.. The S7s sound EXCELLENT with Atma-Sphere OTLs and the S7s' servo-controlled OB bass systems.
Earlier versions of A-S OTLs had switchable bias, but these later versions do not.
Phantom-Audio
326
377
195
Jakarta
www.phantom-audio.com
The SRA Platform for the Atma-Sphere results in an audible sq improvement.
jeffreybehr
187
142
130
80
www.flickr.com
I guess what goes around, comes around. 1-1/2 years later, I'm back to the Serenity Super-7s and the Atma-Sphere MA-1s.. Both pairs of these have been resting in my musicroom, gathering dust.. This WE I reinstalled both and am very happy.. Without remembering that I had done it and wrote about doing so here, I installed the amps with* 3 pairs or output tubes in each amp, and the amps and speakers sound excellent again.
* Doing so (1) increases output impedance; (2) reduces maximum power output, and (3) reduces output Voltage.. My system tolerates all three very well.
Reactions: lordcloud
Phantom-Audio
326
377
195
Jakarta
Neeed to put this into your Room :)
