Power Cable Sequence
LenWhite
424
72
375
Florida
systems.audiogon.com
What is the general consensus as to where to best place your highest quality PC excluding the power amp. I've seen opinions from: it s/b the first cable from the receptacle, to it s/b the piece of ancillary equipment likely to generate the most electrical noise.
audio.bill
549
82
340
Chicago suburbs
They all matter... but most cable manufacturers recommend using your "best" power cable to feed your power distributor to maximize system performance.
BlueFox
1,709
406
405
Why exclude the power amp? I have two power amps, each has its own AC line, and each has its own Shunyata power conditioner, and Shunyata cables. The system sounds much better than just having the amps plugged directly into the wall.
