No, output doesn't depend on volume for every attenuation scheme. I don't think you're quite getting this. I disagree with a lot of what you say... especially on using an op amp vs tubes! ...but I don't want to discuss this in CKKeung's thread.
Good luck with whatever you want to do... I've experimented a lot, built several preamps, etc... I know what I like and what I feel is best.
Despite these issues most do feel the LDR is subjectively better vs resistor based attenuators.
In my system the Kassandra DAC has a high 10v output and uses OPTs,
Yes, the Kassandra also has 6v output SE or XLRs, selectable by an external switch.That's quite high. Can it be trimmed down? A lot of transformers are not designed for 10V.
Lastly, a purely passive resistor ladder attenuator line stage will be a problem for most people most of the time, with clearly audible deficiencies. These types of passive attenuators are probably what give "passive" a bad name in general. It's too easy to use them in systems where they don't belong. Maybe they also give resistor attenuators in general a bad name. Yet resistor attenuators should be the first choice in most active preamps since they're the cleanest option. Just don't use goofy audiophile resistors. $0.30 metal films work great.
DaveC you are addressing bazelio I think?
I think you may be correct about passives. I am going to see how it goes dropping mine out of my system for the first time in 5 years. This subject seems to also align with headphone amplifiers or DAC output to headphone. I have tried a few DACs direct output to high end headphones (not my Kassandra) and it always sounds best with an amplifier. So in that case, where in 'theory' 6v on balanced should be enough it probably wasn't. Maybe enough volume, but not enough drive, something else.
So possibly a passive and it's location inline after the source is the thing that is not working here? Active pre-amps could have the pot in the circuit at the input of part way through it seems, possibly less at the output. Thus a passive is an unnatural item in the chain and may be causing havoc with impedance, current limiting and phase shift / FR shift?
That is my theory at the moment. I am not talking a huge amount, maybe lets say 10% of quality loss as a rule of thumb here. The apparent extra transparency and seemingly increase in speed maybe the typical passive attraction. I wonder if we are loosing stuff in all the other areas instead?
In a budget setup, this increase in transparency can be a free lunch, but in higher end as active pre-amps get better, probably the passive is left behind somewhat. So quite possibly passive as best in low to mid fi, not 'elevated' to high end systems. Caveat, I haven't heard the BeSpoke Audio passive.
Yes I agree, I was saying it is similar in the fact it should in 'theory' have enough drive for the HP, and likewise so should most standard 2V DAC outputs for a power amplifier. But it seems there is more to this than that. The problem in a passive IMO is the fact the pot it at the output, not in the circuit or at the input of the pre-amp. In my mind this could be the issue, though I am not an engineer.Headphones are a very different type of load and dedicated headphone amps serve a purpose. Planars can be very current hungry, for example. Headphone loads typically range between 32R and 300R, and within the audio band can have significant (100s of ohms) variation. The headphone amp itself should be chosen based on its ability to drive the particular headphones you're using.
This is a different topic than preamps driving amps.
