Projector and wifi speakers. Help!
eliaz188
6
1
3
34
Hi! I had a problem, that I try to solve for some time, try to search for information on the Internet but can not ... I have a projector that I want to install in the bedroom, and wifi speakers that are already installed in the room, the speakers have no additional connection in the device itself. I want the projector (or rather the streamer connected to the projector) to transmit the sound to the wifi speakers. Can't find any device that would give me such an answer. The streamer itself can only broadcast on Bluetooth. And I only find devices that broadcast on Bluetooth, and the speakers do not support it as I said. Maybe an app that will actually be installed on the streamer? Something else?
Thank you!
Mike Lavigne
Apr 25, 2010
12,471
11,368
4,410
welcome to What's Best Forum. unfortunately; this is the wrong forum for such a question. you are unlikely to get much help.
try this one. these guys know projectors and related issues. when you ask your question tell them the exact model of projector, streamer, and wifi speakers. that will be important. they may know about your specific gear.
eliaz188
6
1
3
34
I do not think it is complicated on such a level. Just need to know the product that will give me this option. A product that will be connected on one side for aux input and can transmit to a wifi speaker
Addicted to hifi
4,610
2,039
265
52
Australia
it could be a easy fix but if you don’t know how it’s complicated.
Mike Lavigne
Apr 25, 2010
12,471
11,368
4,410
ok, list the exact model projector, streamer and wifi speakers, brand, model, and model number, and we/i will try to help. generic descriptions do not allow us or anyone to be able to investigate sufficiently to help you.
eliaz188
6
1
3
34
Hey thanks! The speakers is from Sonos company, only wifi available...the streamer is mi box s, there's HDMI and aux available, and the projector is a cheap one, Blitzwolf bw-vp6.
I need product that connect through aux and transmitted to wifi. Some adapter... i think that it needs to connect to the streamer.
