PS Audio power Plant
gian60
2,508
1,950
343
Someone has or listen P15 and P 20?
I don't like conditioner but this seems good.
3 has in Italian forum,P 15, and told system is more clear,natural and more dynamic
MRJAZZ
408
208
350
I have several of them, including the P20..... all the things your Italian forum members noted have been observed ( heard).....
The P20 preserves all the original dynamics (and to some degree enhances them), and allows the music to flow in a very natural, relaxed way, with a very silent background....
Cheers......
Legolas
1,042
387
455
France
I have the older P10 and am very happy with it. It helps with my mains supply which I always thought was dirty. I have tried my Kassandra with and without the P10 and in my situation, it is better with it. More dynamics, better bass definition and generally more organic.
I also run my music server off the P10 and LPS supplies, and the Genus Integrated. Running amps of the P10 can be better or worse, depending on the current draw and how dirty your mains is. On current draw, you need IMO to be at 50% max on the P10 or dynamics will begin to suffer. I am at 43%.
Reactions: Alrainbow
LL21
14,423
2,516
1,448
HI Gian, Please let us know if you try the P20. I would like to know what you think. Thank you!
gian60
2,508
1,950
343
Ciao,
now too hot,
will try early september
I don't know if try P 15 or P 20
As i think is better use my CH M1 mono directly to the wall,and i will use for TT,pre and phono,i don't know if try P15 or P 20.
Sound seems to be same,and both have enough power for all.
I will see
LL21
14,423
2,516
1,448
Thank you, Gian60. Look forward to reading about your impressions of P20 or P15. I also would use for sources only.
On Goebel power cord...do you have LaCorde Statement? Do you think you would plan to use this with P20?
gian60
2,508
1,950
343
I havent Lacorde statement but sure i will buy,and also 2 my friends tried and will buy
P 15 or P20 will avoid also the 3 my power distributor,so i will connect M1to the wall and all to one of this,all with Lacorde statement
I think will be very good
Vienna
Hi Gian try aTorus too!
I have tried both the PS and Torus, you will see what I mean
Reactions: sujay
ddk
6,261
4,043
995
Utah
Nothing new, trust your experience !
david
LL21
14,423
2,516
1,448
Hi Vienna,
Thanks...did you try the latest P15 or P20? I have heard great things about Torus.
LL21
14,423
2,516
1,448
Thank you. I have Burmester 948 Reference which works nicely now.
Vienna
Hi Vienna,
Hi, I have tried both the P15 and P20. A listening test with Torus AVR is highly recommended!
Legolas
1,042
387
455
France
Hi Vienna,
Torus as far as I understand it is not a power regenerator, more an isolator? An advanced low pass filter.
The PS Audio units take AC back to RAW DC then clean it and regenerate a clean AC sine wave.
I haven't compared the 2 products. It is also situation dependent i.e. how bad your mains is, and the load you place on the unit doing the work.
Reactions: MRJAZZ
LL21
14,423
2,516
1,448
Thank you both Vienna and Astrostar59...I currently use the Burmester 948 Reference only for sources...Digital and preamp so low powered. I cannot imagine running the Gryphon through this.
Vienna - how did the Torus and PS P20 compare?
gian60
2,508
1,950
343
I know David doesn't like any tweaks,so is like he tells me don't waste time and money
gian60
2,508
1,950
343
P 20 i can try because i am friend os distributor,while Torus has no distributor here and cannot try
Elliot G.
3,324
3,034
1,910
Fort Lauderdale, Florida
www.bendingwaveusa.com
Gianni, I had a PS 20 in my system and also used one at Axpona this year. It is a good product however I recently got the Nordost power purifier and the QB8, and Qcore and IMO it was much better. I have good consistent power in my room so that was not an issue of me.
gian60
2,508
1,950
343
Thanks,
i know this product but never tried,i will check well.
And put Nordost Q4X between the wall and P20 could be give more pure and regenerated power.
Hope David don't read this
LL21
14,423
2,516
1,448
I do like the QX4 between the wall and the Burmester, as well as wall straight to Burmester and then to QX4 to CJ Preamp.
ddk
6,261
4,043
995
Utah
Caro Gian,
Of course it's possible to improve your sound by upgrading your mains electrical installation but do you really believe a little box regenerating in your room can compete with this :)?
Fix problems the right way!
david
