Recommendation Needed for AMPS to pair with JBL 4350 LF
jackson_k
83
17
90
Los Angeles
Hope everyone is stay safe and healthy.
I currently is running a JBL 4350AWX and the HF is clean, detail and just beautiful , however the LF seems to be lacking clarity and that round glorious bass,
I am currently running a boulder 2060 Class A 600w on it... but I honestly can't say that I am not " FEELING " it ,,, so just want to check in with you guys if
there was experience from the community.
I am planning to use a CROWN XLS 2502 , or a QSC RMX series to see if the higher power will create a better control over the dual 15" woofers on each speaker.
Thank you for any advice !
JK
olivier
89
59
285
Munich
i don´t think that a PA amp would be as good as a 2060
i tested a xti 4002 and apart from power there was nothing like a good audiophile amp i like. too slow, too less resolution...and watch out the fans, they can be too loud. with the xti 4002 there is no problem, they are off most of the time, but i had a Lab Gruppen FP7000 and these are incredibly loud
perhaps soulution is a solution for your problem. they are fast and have a great damping factor
thomask
1,623
1,539
275
64
Washington State, US
I had tried Crown Xls 2502 with Raal Sr1a headphone which is power hungry.
It sounds clean and fast.
Now I am using two of them bridged to drive my two 18 inch Scaena subwoofers.
You may try it with only 650$.
Solypsa
1,811
1,401
275
Seattle
www.solypsa.com
Try Ashly for an old-school pa amp...much more stable than xls....
Solypsa
1,811
1,401
275
Seattle
www.solypsa.com
Or a pre class d MC2 amp...
