Record Brushes
Audire
1,479
1,833
330
FL Panhandle
I was wondering what everyone uses in the way of a brush to clean their records.
We have an AudioQuest, but it is only so-so. The Levin Design Dry Cleaning Brush is the one we settled on. It’s made in Germany using hand-pulled horse or Chinese goat’s hair.
Reactions: Long Live Analog
ACHiPo
519
309
310
Pleasanton, CA
I also have a relatively new Audioquest brush that does not work well. I just ordered a Hart audio based on Fremer's review.
Hopefully it works better getting dust and hair off records between wet cleaning.
jeff1225
3,013
3,265
1,410
51
I have used the Hunt EDA Mark 6 brush for a long time and it has served me well. I ordered the Ramar Berlin brush and will receive it this week. I'll be sure to report back.
twitch
602
246
1,605
SE Pa
What's important to remember is that any brush that doesn't provide for a conductive path for static electricity is useless. My favorite of all time unfortunately is no longer in production.....
DasguteOhr
2,438
2,619
645
Germany
Swiffer works great;)
Audire
1,479
1,833
330
FL Panhandle
Personally, I would be scared that one of those feathers would grab my cart in a mistaken moment … Opus1 bye-bye. So the Swifter won’t continue to collect dust when not in us what do you store it in?
DasguteOhr
2,438
2,619
645
Germany
microfibers aren't that flexible, you don't have to clean the record on the side of the tonearm ;)
i store them in a freezer bag in the drawer near the turntable, really good resultats with the swiffer dust magnet
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
mine arrives on Thursday.
great minds think alike! ;)
Audire
1,479
1,833
330
FL Panhandle
Well that’s a given not to clean near the tonearm, but those are still long feathers. I’m thinking what if a feather releases from the handle, etc. And I have multiple tonearms. The freezer bag makes since though. Thanks.
Nathanu
36
54
173
I have been using the Ramar for the past 4 to 6 weeks. Generally it is a good product and functions as designed. The magnetic case is nice. And it looks good. Two cautions:
(i) The fibers are very soft; if you push too hard while holding the brush on an angle, it is easy to bump the corner of the handle onto the record.
(ii) It sheds. It seems that the shedding is settling down now but it will be important to watch out for stray hairs. The brush comes with a circular felt/corklike pad for cleaning the brush after use. It is a good idea to run the pad over the brush before use as well.
Nathan
Kingrex
2,943
2,409
350
The idea ofna swiffer collecting dust next to it. Has anyone ever thought to try and produce a device that has a greater magnetic draw for dust than your record. Something that hovers over the platter and draws dust up to it.
Reactions: Audire
twitch
602
246
1,605
SE Pa
again, it all come back to knowing how to deal with static electricity !
bazelio
2,494
1,748
345
California
For static electricity....
Reactions: AudioHR and Audire
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
no. what you want is negative ion's removing the static which releases the dust. a vacuum will create/increase static cling. the right natural bristle brush is a good compromise. but not perfect.
Nathanu
36
54
173
Has anyone compared the IME1 to the DS Audio ION-001?
twitch
602
246
1,605
SE Pa
Reactions: ACHiPo
Audire
1,479
1,833
330
FL Panhandle
The DS Audio ION-001 looks like it’s nice. I’m going to have to find some reviews.
