Reviews
Jul 9, 2018
64
9
13
A very informative review of the Small Green Computer sonicTransporter i5 and original Sonore Signature Rendu.
https://forum.audiogon.com/discussi...all-green-computer-and-signature-series-rendu
My favorite quotes:
The STi5 arrived first. I loaded my digital music library (about 500 GB) onto it without difficulty. Then I compared the STi5 to my 2017 MacBook Pro as a file server, using the Chord Mojo DAC for both. I can't remember exactly how I hooked up the STi5 for this comparison; but it was one of those situations where the improvement was so immediately obvious that I didn't spend much time on it, and haven't looked back. My remaining impression is one of a more stable, solid and clean sound using the STi5.
DAC manufacturers tend to overstate the independence of their DACs from the quality of upstream components; and my upgrade strongly confirmed this belief. Not to put too fine a point on it, my DAC sounds at least twice as good as it did before I inserted the SGC server and Sonore renderer. I was puzzled by the brief but rather sweeping character of some SGC and Sonore reviews, until I reached the same conclusion: my system was now producing the best sound I'd ever heard at home.
Jul 9, 2018
64
9
13
Set up my i5 sonic transporter last week. This replaces my MacBook.....no contest. The system is quieter, better separation, imaging and clarity of vocals and instruments. And at that price, it’s a no brainer......happiness!!
Sujay - Thank you for the feedback. Much appreciated.
Reactions: sujay
spiritofmusic
12,116
2,807
653
E. England
Have pretty much whittled down my streamer/server options to SGC i5 w MicroRendu and LPS to supply both (or Roon Nucleus/Innuos Zenith), into something like an MHDT Orchid/Lab12/Kitsune Holo Springs dac.
I have no reservations about likely SQ, all reports on SGC have been uniformly excellent, as per Sujay.
I'm really interested in things like user interface, esp as a customer who has zero skills in computer audio, and likely v little input from a 3rd party.
Any comments on Roon Rock used on Nucleus versus Linux on SGC?
Reactions: sujay
sujay
454
143
385
Singapore
The Zenith is also quite compelling. I finally went down the Lumin U1 route because I got a good price on a used one. Otherwise, my first choice would have been the Signature Rendu optical. I would suggest if you are going down the Sonore route, go whole hog for the signature optical.
spiritofmusic
12,116
2,807
653
E. England
Sujay, not Roon Nucleus/Plus?
sujay
454
143
385
Singapore
i haven’t heard the nucleus plus but I guess it is also a one box solution streaming to the DAC. I always prefer a more modular approach that allows one to change components at a later date. A one box solution is always a commitment that removes this flexibility. Having said this, I would wager that the Signature Rendu optical would beat the nucleus plus.
There is a Darko review, linked below, which probably says just that
https://darko.audio/2018/08/roon-labs-nucleus-review/
spiritofmusic
12,116
2,807
653
E. England
Can you send me a link to Signature Rendu optical?
MicroRendu not sufficient?
agillis
The microRendu is a great music streamer. It sounds much better then using a computer or a Nucleus (as a player).
The next upgrade is the opticalRendu. The opticalRendu has an optical network interface. This eliminates all noise from the network.
If you really want the best sound get the Signature Rendu SE optical.
https://www.smallgreencomputer.com/collections/systemoptique/products/systemoptique-se
spiritofmusic
12,116
2,807
653
E. England
Agillis, and which Sonic Transporter are you using w the Signature Rendu SE Optical? i5 or i7?
agillis
Both the sonicTranspoerter i5 and sonicTranspoerter i7 work very well with the Signature Rendu SE Optical.
I use the i5 CDR myself as I don't do any DSD512 upsampling. You only really need the i7 for upsampling music to DSD512.
spiritofmusic
12,116
2,807
653
E. England
Agillis, there are a couple of options on the Sig Rendu SE Opt, impvd internal components, taking the price to c$4.5k. You'd advise this route?
Can I ask how you've come to the decision to go SGC/Sonore over alternatives like Innuos Zenith or Roon Roon Nucleus?
agillis
The Signature Rendu SE Optical are all built one at a time by a Sonore engineer in Colorado. In his spare time he he had some ideas for how to improve the sound and he tested them out in his listening room. These improvements are small but you can hear them on a very reveling system. These types of upgrades are for our customers that want the best of the best and money is no object. We sell them as the Tier I and Tier II upgrades for the Signature Rendu SE Optical.
The Roon Nucleus is a great server but it's just a stock NUC running ROCK OS. It does nothing to improve the USB connection to the DAC. Many people use our players such as the ultraRendu with the Roon Nucleus. This is a great combination. Our sonicTransporter server has more features then the Nucleus so many customs get one for that reason.
The Innuos Zenith uses a stock or slightly modified PC motherboard with nice linear supplies to power it. The sound out of these is much better then a stock PC or NUC USB port but not as good as a you get with a dedicated Ethernet to USB player such as the Sonore Rendu players.
Also may Innuos users have complained that the Innuos Zenith is not fast enough to run Roon Core. It's Intel Celeron processor is just barely at the low limit of the spec for Roon core. You get much better Roon performance using an i5. So many Innuos Zenith owners use the Innuos Zenithas a Roon Ready player and use a sonicTranspoerter i5 for their Roon Core.
spiritofmusic
12,116
2,807
653
E. England
That's Andrew, yes? A pleasure to chat to you. For a few reasons (reluctance, even if fast receding, to finally not rely on physical media; lack of budget atm, and anxiety on making the wrong choice - I don't have any mainline dealer relationship, and am all thumbs and pounding headaches when it comes to computers LOL), I'm not rushing into things.
I have to say I like what I'm seeing re Sonic Transporter and Sonore, and they're gradually rising to the top of my shortlist.
Andrew, any thoughts on people's reticence on Linux, which I believe is yr platform? I've spoke to two streaming guys who swear on Windows as the OS over Linux, esp for music demands. I can't really comment, just curious re yr thoughts on their antipathy to Linux.
agillis
Our units are all plug and play appliances. No computer knowledge necessary. :)
Everybody has their opinion but the consensus in the industry seems to be that low latency Linux is the best for audio. This is what we have found is our testing and all major music servers and players today are based on Linux so my guess is other engineers have found the same.
From a DIY prospective Linux may be a bit harder to learn then Windows but for a ready made product that shields the user from the operating system Linux is the way to go. Maybe your streaming guys are DIYers and want a desktop OS.
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,657
639
485
San Diego, CA
almaaudio.com
The Innuos Zenith is perfectly capable of running Roon Core. It will only choke while doing DSP/upsampling with DSD. With PCM upsampling/DSP, it'll work fine, and, of course, it'll work even better with none of it.
I've found out that with servers, faster is not generally better.
I've found out that the Innuos running Roon Core, even the little Zen mini, sounds better than a computer running Linux, even over Ethernet.
agillis
It will also choke with large libraries. But yes as I mentioned it does meet the absolute bare minimum spec for Roon.
Many of my customers would agree with this as well. This is why they run Roon Core on a sonicTransporter and use the Innuos Zenith as a player only.
I agree with you that low power CPUs are better. That is why our Sonore Rendu players run on super low power ARM processors. They sound much better then attaching a DAC to a high powered computer.
